I plan to replace all my T12 fluorescent tubes with double ended ballast bypass T8 LED tubes ... and I have a couple of basic questions that I haven't been able to answer.
1. My T12's are all rated at 40W, 4100K and I have a mix of tubes with design outputs between 2200LM and 3000LM. I'm trying to figure out what LED tubes to buy that have a comparable output. It would seem that if I replaced ... as an example ... a 2200LM T12 fluorescent with a 2200LM T8 LED that I'd be good to go ... but I read that for an equivalent lumen output ... an LED tube will be brighter than a fluorescent tube ... which makes no sense to me ... lumens are lumens ... right? So ... what criteria should I be using and what T8 LED lumen rating should I be looking at to replace my T12 fluorescents?
2. In the garage I plan to go with 5000K T8 LED tubes and 4000K in the kitchen and bathrooms. If I went with 5000K in the house rather than 4000K ... would it be that big of a difference? From pics I've seen it doesn't seem to be ... but I've never seen it in person.
Thanks!
KenB64
Thanks!
KenB64
