olds70supreme
- Joined
- Mar 7, 2008
- Messages
- 696
I'm putting up new shelves to store spare lumber. Top shelf is 10' long and stores 10-12' lumber. The bottom shelf is 8' long and stores shorter pieces, cribbing, etc.. Sheet storage goes underneath (already in place). As shown they are lagged to the two walls but have no support on the edge away from the wall. The obvious answer is to drop a 2x4 down to the ground - BUT - I don't have room to slide the sheet goods or the 10' lumber off the end of the shelf, so I would like to keep the front of the shelves clear of supports.
How bad of an idea would it be to install a piece of 3/4 plywood at the end of the 8' shelf to provide support for both shelves? First, push the insulation aside, but the edge up to the exterior wall sheathing, and secure to the stud wall. Then attach to the end of the 2x4 on the 8' shelf. Last, attach the top of the plywood to the bottom of the 10' shelf.
I crudely sketched what I have in mind. Is this a terrible idea, and if so are their alternate ideas that keep the area above the 10' and below the 8' shelf clear of supports?
Thanks.
Thanks.
