knipex : cobra or alligator?
pete379
I own neither, but considering buying, which one cobra or alligator? and why ? (or pro/con)
thanks,pete :)
Z06 427
El Cajon, CA
Don't buy the Cobras. Once you buy the first you will want the whole set. Same with the plier wrenches.
fatfillup
Finksburg, Md
I have owned and used both for quite a while. I used alligator for many years (15+) and love them. Got my first cobras a few years back and didn't care for them at first as they were stiff to adjust compared to the alligators. After using them a while and getting them broke in so they adjust easily, I probably prefer the cobras. The adjustment stays locked in place until you push the button and move it. The alligators will move on their own when you sit them down.
The alligators open wider then cobras which can be an advantage. If I was buying new and paying retail, I'd buy the cobras. That said I bought a pair of alligator 10 inch at an auction Friday night along with a few other pliers and paid $17 for a new pair of alligators and the others.(the others weren't much) I'd have gone a little higher if necessary.
To give you an idea of how much I like and use them, I worn out at least 5 pair and my regular customers know if I ask them to get my red pliers, they come back with the right tool.
You can't go wrong with either but I'd reccomend the cobras
NOTE: They are used multiple times daily and every mechanic that I have had has bought at least 3 pair after using mine.
Monte
Germany
<object width="640" height="385"><param name="movie" value="http://www.youtube.com/v/iwzfaII3zYw&hl=de_DE&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/iwzfaII3zYw&hl=de_DE&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="640" height="385"></embed></object>
Fedwrench
Valley of the sun
Screw the snake, buy alligators. I have both types. I personally prefer the alligators. I'm not a fan of the push button adjustment despite it being easy to use. I'm just a dinosaur and my personal preference is the alligators. Both types will serve you well.:beer:
cortez
Chicago
I use both but in very cramped quarters (or groping blindly in the belly of some machine) the alligator type does not get accidentally readjusted due to unintentional engagement.
Both are superior pliers. :thumbup:
wellstig1
Torrance, Ca
I have EVERY size of the cobra and I like them so much I find excuses to use them on things you normally wouldn't. I've tried the alligators and not having the push button I'm used to sucked. I also have all of the plier wrenches which are great too.
wantedabiggergarage
Member Emeritus
Independence, MO, USA.
I have the Cobra's and then regular water pump pliers when getting into the larger sizes (16"), as I don't use the larger ones enough to justify them, yet.
However, watching the video, I learned something new. I have NEVER seen them with the comfort grip, so is that an add on?
FNFS2000
Alligator blows. Especially with all the new fat opening cobras out. Bahco is ok, but knipex is the king, nobody else grips like them, and the new design rocks.
fatfillup
Finksburg, Md
I used to have pair of bahco adjustable but don't know where they went. Anyone have both to compare the push button bahcos with the knipex cobras?
I bought a pair of16 inch bahcos off ebay from a link here a while back. They were about $36 with shipping and were new. Then bought a similar size cobra used at a sale for $35. After using both, the new bahcos went in the showroom with a price tag on them. The used cobras grabbed harder and didn't slip. The bahcos weren't bad and I really liked the way they adjusted but the didn't bite as hard.
walrus
Maine
At least I learned how to pronounce Knipex from the video:thumbup: The Cobras are nice pliers, they grip pipe really well, I've used the **** out of a pair and they still work like new. Mine are used nearly every day and I've installed 1000s of feet of 3/4 rigid conduit. Didn't like them at first and guys who use them for the first time don't seem to like them if they're used to Channellocks.
garfunkle24
Saskatoon, Canada
Cobra FTW: :D
Flash21
MIght be a little off topic...
When Knipex made the change to 'extra capacity' on the cobras, did they make the change to the 7" pair? I've been waiting to buy them because I want the latest 'extra capacity' version if they are changing the 7". I know my 10" Knipex are an updated design from my 10" Cman / Knipex rebadged.
garfunkle24
Saskatoon, Canada
I'm sure they did. My 6" and 5" are updated.
See here:
New Knipex products
Part# 87 01 180 - 30% more capacity
