Craftsman Ratchet Question.
Scout Driver
South Dakota
Small question about a small part. While doing a cleaning/lubing job on my ratchet, the small ball that is between the spring and pawl "vanished". :mad::mad:
Anyone know the size of the ball? Ratchet in question is a Craftsman 3/8" drive -V- 43785. Thanks. :beer:
Scott
BanjoSavesTheDay
Huntington, WV
Aaahh I don't know the size of the ball, but I feel your pain. I just cleaned a similar ratchet and came very very close to doing the same thing.
woody 73
The Great State Up North
I too do not know the size of the ball,but I also feel your pain! One trick I did learn might help you in the future is this;(I put a lot of grease on the spring and the ball,the grease acts like glue,just long enough for me to get everythong back together).
I have lost enough little parts through the years,so I feel your agony.
Good luck in your search.
mkdive
NPB (Socal)
I bet if you go into your local sears, they would give you one free if not the entire rebuild kit. Mine gives me rebuild kits for free when I ask.
bonneyman
Desert SW
I was just taking a new Craftsman acquisition apart - a 1/4" 43175 "B" ratchet. But the thing was so stuck with old/dirty grease I had to wrestle to get the ball and spring out of the hole!
I save ball bearings from bikes as I find them. Keep them catagorized by size in little bins - you never know when you're going to need one. I'd be willing to bet one would fit.
The springs are much harder to match. I collect springs from old ball point pens in a little bin for just that reason.
SCscoutguy
South Carolina
Will they give you rebuild kits for the older V series ratchets as well or just the new tear drop kind?
Scout Driver
South Dakota
---Status Update---
Someone had a ball bearing in their "stash" today that was a match! With the help of a heavily modified curly-fry cutter made into a "ball bearing pusher-downer apparatus", I got the ball in and the ratchet clicks like new! :thumbup:
Thanks to everyone who posted with words of wisdom and hope! :beer:
Scott
phi2039
Baltimore, MD
If there is enough interest, I would be happy to post a video of the 'insider secret' to getting those little buggers put back together... No modified curly-fry cutter required :)
Bigpigdave
Camden, IN
Please post the video, I am always open to learning.
Thanks
bonneyman
Desert SW
If it's one of the older "oiler" port styles of ratchet, you can hold the ball down with a drill bit thru the oiler hole as you push in the pawl. The newer styles don't have that hole - it's takes a bit of finesse!
BeninTucson
Tucson, Arizona, USA
Just rebuilt my 43785 . . . and, yes, the little ball bearing went flying, but was eventually found after cleaning the work floor with magnet and flashlight in hand. Exactly the same thing happened last month when I restored a recently purchased Challenger 10601 (you'd think I'd learn by now.) :dunno:
Anyway . . . I measured the ball bearing while I had everything apart and degreased. It appears to be 1/8" (or 0.125",) but my calipers were telling me it was actually closer to 0.135".
Cleaning hint: I keep a bottle of B100 biodiesel (not to be confused with petroleum diesel) around the shop for metal cleansing. This corn oil product does a great job of cutting through rust and removing decades-old grease muck. It also is easier on the nose and hands than ATF or WD40.
When reassembling, it's time for the white lithium grease . . . especially a dab to keep the ball/spring assembly together. A small flat blade screwdriver is the only tool I needed there and needle nose plier for the spring clips. I also spread a layer of grease around the gears. Once everything is back together, I clip on a large socket, hold onto it and spin the wrench handle around quickly like a party noisemaker in both directions for a few minutes to spread the grease around. Now, this old ratchet feels as smooth as the day I bought it (or my father bought it for me) some 4 decades ago.
Ben in Tucson
