Horn: That is a thing of beauty there sir. You do fantastic workWhen I posted my Craftsman drill press on this thread earlier this year, it was a 150. I have since found an early 1958 100 in power bronze and did a swap out. I also found a very good condition MSA for under $100. I've just put the motor back together (again), this time with an original sardine can capacitor and new bearings and it absolutely purrs.
The mobile base is also a new addition. I looked at so many different models and decided on the harbor freight. I hate saying that, but it just seemed to be the best designed in my opinion. I don't roll it around the workshop much but when I do it's pretty easy. You can see it has the hold downs but I typically don't need them because the Press does not move whatsoever when in use.
Funny you should mention that Deker lolHoorn, that machine has all the bells and whistles. Absolutely gorgeous. All you're missing is a foot pedal switch!
What is any old thing worth? Something is worth what someone is willing to pay for it.Good morning. This seems expensive.
1950's Craftsman Model 150 Drill Press w/ Variable Speed - tools -...
For sale is an original 1950s model 150 Craftsman drill press featuring the variable speed drive that is very hard to find. Makes woodworking or metalworking possible on the same machine with ease....phoenix.craigslist.org
$800 is crazy. Figure a vari-slo in "great condition" on its best day is worth $300. That means the rest of the machine is worth $500. It does not have the original motor, and it looks like someone drilled four holes in the head frame most likely for a receptacle box, further diminishing it's value. I'm all about power bronze, but that 150 without the vari-slo, with a desperate buyer would fetch $200. So it's very safe to say he's about $300 too high.
No offense taken whatsoever. We're all different and come at these things differently.Hoorn, after re-reading my previous post, I realize it sounded abrasive and that was not my intent. If I offended anyone, please accept my apology. I was just typing what my though cloud popped out and not considering how it could be received.
I also agree that both you and I as well as many others here are a bit more knowledgeable about these DPs and the accessories; and yes we have more experience on how to locate and get good deals on these DPs.
Hoorn, Subroc, and y’sguy; you all make good point and I agree the value of these machines is intrinsic to each byer.
That's a beauty Hoorn! I've yet to find an Atlas lift.I have since found an early 1958 100 in power bronze
That's a nice looking 100 Myers. Between the 100/150 I like the power bronze 100 the most, and believe it had the shortest run of all the different configurations. You obviously know your way around a CDP based on that restoration.Well I just picked up my second drill press. I restored the first with help from the information in this thread.
I bought this press with the intent of taking the low speed pulley off and installing it on my 1957 100. However, I think I’m going to keep this one as well.
It has the optional collar lock and low speed pulley. It also has a light bulb added inside the head.
I did notice that the base is from a bench model, but the column is from a floor model. Was it ever an option to buy a press as this one is configured, or has the column or base been replaced later on in its life?
I am tempted to cut the column down in order to make a correct bench model, but thought I’d ask first.
I’ll be looking for a correct motor if anyone has one.
The last photo is my restored floor model that now has a twin.
$100 for a power bronze 100 with an MSA pulley is a "you ****!" price. Well done!Thanks Hoorn, it's in pretty good shape.
I paid $100 for it. I planned on taking the pulley off and reselling the rest of it, but I have a thing for power bronze apparently, so I think I'll hold on to it. My floor model will be my wood DP, and the new one will be dedicated to steel.
If it was offered this way from sears I'd keep it a floor model, but I think the column has been swapped out. I looked through several of the craftsman catalogs and couldn't find anything that showed or mentioned optional bases.. Shortening the column should be easy enough.
Yes, I was so busy answering the question I failed to bring up how much eye candy is in that picture, including that articulated Heritage logo lamp. Nice setup there.@Myers B Dig the matching block grinder!
You mean like the 48-50 Ford Pickup hiding in the garage?Man's gotta know when he posts on GJ, every nook and cranny of that picture is going to be dissected and guys will find every last tool in that frame even if there's only 5% of the tool visible lol.
Exactly!You mean like the 48-50 Ford Pickup hiding in the garage?
Dude, that isnt a bad price compared to what I have seen some advertised for!Personally , I think they look better without the cover but if anyone is looking for one.
