I am having a metal building put on the property. It is one of the prefab galvanized 2" tube frame carports with the sides and ends enclosed, so not real heavy. Comes on a trailer and a few guys slap it together in a day or two. It will be installed on a concrete slab. My county wants me to put footers 42" into the ground due to local codes and weather (cold winters, hot summers - OHIO). Unfortunately, if I do what they want, it will price me out of my own project. I had a few concrete contractors over and they all laughed when I said the county wants me to put footers for this application. They all said its NOT necessary for this type of building.
So, with no footers I would like the concrete to be as strong as possible for long life without spending the extra thousands that footers cost. I was thinking 4" thick concrete, 4000 psi, fiber reinforced, AND rebar. This is in additon to having the ground heavily compacted to avoid moving and busting up the concrete as the weather changes.
My questions are:
What specs should I aim for as far as the aggregate base to be used?
What specs should I aim for in terms of the rebar diameter and rebar spacing? The slab dimensions are 27' x 31'
I do not have much experience with concrete, so I am open to suggestions.
My questions are:
