remagenman
- Joined
- Oct 30, 2011
- Messages
- 439
I want to install a outlet box on the exterior wall of my sub panel box, meaning the sub-panel is mounted about 5 feet, next to main panel on my garage wall, next to door. I have a planer and some other 110v power tools that sit right outside my garage and usually run an extension cord from directly inside my door to run these.
The best location for the outlet, because I already installed exterior 220v outlets for welder, etc., would be directly behind sub-panel back bottom knockout, directly facing my exterior wall its mounted on. So it would be = sub-panel, wall sheathing, outlet box. The wall/sheathing is a 1/2 inch thick.
Problem I'm facing is what connector can I use to transition from outlet box 1/2 screw hole through wood and into metal sub-panel box?
Is this even allowed?
ps, sub-panel knockout and outlet directly behind it would be mounted 5 feet up from ground level.
Thanks.
Thanks.
