Donttouchthat
Hope I can get some input here. I have a 200A main service panel for my house and 39 of the 40 slots are filled. Researching the panel (GE Powermark Gold # TM40BC) I see that tandem type breakers can not be used. I am trying to do a couple of things that am in need for more space so a subpanel(s) I think are needed. Due to a kitchen reno I need 2 additional 220v circuits. One for a single electric wall oven (2500w, stated at 20A). And the other for an electric cooktop (60hz, 6400w, stated 35A) In addition to the 2 lines, I want to run between 40-60A line out to my detached barn which I am renovating to include about a 550sf finished space with the remaining 300sf being left for garden/small workshop.
The attached drawing shows what I am thinking for the barn feed. My thought are to get a 100/125A subpanel to be adjacent to my main to get the extra lines I need. The oven states less than 4800w can go with 20A breaker. So 12/3 or 10/3 wire with a double pole breaker. The cooktop is an Italian brand with three wire (Black, Red, Green, no neutral) The manual says a 4 wire connection from supply and just cap off the white neutral. Does that sound right? Then the main other thing is to provide a feed out to the barn which I am planning a 4' deep trench that will contain all (LV pvc conduit, 2"conduit to run 3/4 PVC water line, 2" conduit for power line). The power lines would come into another subpanel. Maybe these would be 4 single type wires, and this panel would have a main shutoff. Does the main subpanel in the basement require a main shutoff (100A) as well? It is not practical to continue trench conduit that is entering the basement all the way right to the main subpanel. That is why I show a junction box but not sure if its kosher. Lastly the barn has electricity from line run from a 20A GFCI outlet in my house that goes in the ground through a conduit (15lf) into the barn. I don't know if that needs to be disconnected when the new line goes in, but I was thinking to keep it for outside barn lights and 3 way switch from house capability. Thanks for any input and/or questions!
