SAYING GOODBYE TO THE SAILBOAT… (Part 17 of 20)…
SAILS AND LIFTING MAST
I final made it to the point of checking out the sails. This one has two, and main and a jib. When the boat was pulled out of the water years ago, the boom and main sail were stored in our little garden shed. I was glad for that because it preserved the sail nicely. Of course, proof of that preservation won’t really come until it gets put back in action, but I tugged on all fitting pretty hard and I think it has a fighting chance.
There were some discolored spots, mainly along the vertical leading edge that cleaned up well with a 2 hour soak in a bucket of Oxi-Clean solution. Some scrub brush action took care of the rest of the spots.
In order to get some pictures with the sail up, I decided to see if I remembered how to raise the mast. Hunter made this a fairly quick process because it’s something you need to do when you trailer the boat somewhere.
You slide the mast back from its trailering position to connect the bottom end in the hinge.
Then you use the mast raising pole to gain more leverage and winch the mast upright.
Here is the mast fully raised and front and side stays in place, ready to sail. It’s a one person job that is best done on land.
Here is a shot with the boom and main sail added. Again, that Sunbella material is awesome to still look new after all these years.
And up went the sail. I thought it look sort of cool next to the building. At the same time, I feared a gust of wind might come by and shift the boat on the trailer.
Another view. I can tell the sail must have shrunk over the years because the tips should have reached the black rings on the mast and boom. Perhaps a stretch in the wind will let it do so someday.
Here is one last image with everything installed like you were ready for a day of sailing.
