ukiltmybrutha
- Joined
- Apr 23, 2016
- Messages
- 689
Hi,
I have a GFI outlet in my garage that is in a convenient spot but I'd like to split it using something like a 6 way wall socket. Further, I don't understand why there is a water resistant GFI outlet located in my garage when all of the others are just standard receptacles.
Can I just throw one of the below onto the GFI outlet for simplicity? I like to keep it simple. I could run 2 surge protectors but there are times where that can be messy and this can be one of them. I would think that I can't get away with that type of splitter because it will stomp on the outlet buttons and cause more issues.
www.homelectrical.com
Maybe I should just put a normal non-GFI outlet in it's place considering that even receptacles that are just a few feet away but far enough away where they are not convenient are just standard receptacles anyways or is the single GFI outlet just there to meet code maybe?
Thanks.
Eaton Wiring 125V 6 Outlet Taps, Duplex Receptacle, 15A, White (Eaton Wiring 1146W-SP) | HomElectrical.com
Buy Eaton Wiring 1146W-SP 125V 6 Outlet Taps, Duplex Receptacle, 15A, White on HomElectrical.com. FREE SHIPPING with minimum purchase of $75.
Thanks.
