Hi both,
Thank you for your answers, very helpful
Can anyone explain why the C6 and E6 doesn't offer the same profiles?
For instance why Torx Plus is not part of the C6 range?
Sorry but this doesn't make sense to me.PB Swiss doesn't offer them, but C6 are commonly 25mm long but longer and shorter ones are available. E6 are 50mm long or longer, and may have reduced diameter shafts for easy access to recess/obstructed screws.
Well, I was likely drunk at the timeSorry but this doesn't make sense to me.
PB Swiss makes C6 bits in 25mm. You can even buy a set if you want.
Well, I was likely drunk at the timeLet me try again...
PB Swiss makes C6 bits in the common 25mm length and not in other lengths as far as I know.
I have found other lengths to be useful: 12 to 19mm used with bit ratchets in tight spots and 30 to 35mm bits used with some stubby drivers. I also have 150mm long C6 bits that are useful with some bit holder/drivers.
Who sells 12mm long insert bits?Well, I was likely drunk at the timeLet me try again...
SK11: https://www.amazon.co.jp/gp/product/B00CRC2HEQ/Who sells 12mm long insert bits?
I have seen the VIM "half cut" but they are 16mm. What are other suppliers for short/stubby insert bits?
