Dave455
Very nice!
I guess it‘s “thread drift” if I say that I really like the look of those Elora’s!
I bought these without a clear understanding of what they were intended for, but I thought they would serve to mark/punch. I'm hoping someone with an understanding of Japanese language/techniques may help:
Amazon | トップマン コンクリート針 大 2本入 | 差し針
トップマン コンクリート針 大 2本入が差し針ストアでいつでもお買い得。当日お急ぎ便対象商品は、当日お届け可能です。アマゾン配送商品は、通常配送無料(一部除く)。www.amazon.co.jp
"Concrete needle"
i believe it's for tiling work to anchor string guide
That’s good to hear about the grip! Yes, I got the 3/8 and 1/4 mixed up.I have that ratchet. For reference, the 1/4 drive Zeal is 36 tooth, not 72.
The Zeal grip is make of a really tough material. I don't know what it is, but it shrugs off oils and solvents. None of mine show any deterioration or even wear.
What weld are you talking about?
Oh, I think you mean the end cap on the hollow handle of the Nepros ratchets, which is welded on, then ground and polished so well it doesn't show. Of course it's not under any real stress, so strength is a non-issue.I thought I read here about the end being welded on. Might have saw it on YouTube.
Not quite sure what you mean, but the head has only one detent at the 180 degree (straight) position. There are no other stops, but the head is under tension — it doesn't move around when I shake the ratchet. I put a 17mm deep socket on it, and the head stays put at any position or orientation (in other words, if I tilt the ratchet down while the head is at an angle, the weight of the socket doesn't move it.)How does the head hold up with flexing? Meaning does it flop around like a wet noodle?
I just recently bought those pliers from amazon as well. Actually came into use the other day......... changing out the pull switch on a ceiling fan. Some other pliers would have gotten the job done, but this was easier. Always some satisfaction when using a new tool for the first time and it makes the job easier, which is why I purchased it in the first place.Some how this came in my Amazon order today. I didn’t order it on purpose but was in my list to get later. Oh well…***** to be me!
I like it. Good feel and well built. I thought this might be good for regular slip joint pliers-type of thing (and to some degree it is), but it’s really about the grabbing the head of fastener or the nut.
Truecraft Tools
Was this brand ever produced in the US, or has it always been overseas?www.garagejournal.com
Me neither but i found this older thread
TrueCraft made tools both in both Japan and New Jersey. Their ratchets, torque wrenches and combination wrenches were quality pieces. TrueCraft was a brand of Daido. TrueCraft Tools disappeared from our shores around 2005. Here is some history: http://alloy-artifacts.org/japanese-tool-makers.html#daidoTruecraft Tools
Pruners
I'm no gadener, but these are sweet. Nice and sharp.
From the Ko-ken USA website: "Koken warrants that each product sold by it shall be free from defects in material and workmanship under normal application, use and service for the life of the product. Koken’s sole obligation under this warranty, in Koken’s sole discretion, is to repair or replace, free of charge, any part or parts found to be defective, provided that the product (i) is delivered, postage prepaid, to Ko-Ken USA, LLC, 10 Kidder Road, Chelmsford, MA 01824; (ii) has not been misused, subject to unusual stress, modified or serviced in any manner."Also, does anyone know if a cracked socket will get warrantied or should I expect to buy another if I break one? Not sure how Koken handles broken items or if their warranty is as good as what I'm used to with tool truck items.
I saw this myself when browsing Koken's catalog, but couldn't find anyone selling them. I suppose I could send Palmac an email to see if they have them.
The sleeves seem to be well made so I doubt I'll have issues with them, still would be nice to have a source. The socket itself is much nicer than the standard wheel sockets being sold by other brands and are much better at protecting wheels.
the real answer to your question requires more info about what you're ordering and how it's declared.
brief explanation:
- declared total value of under $800: rarely inspected because $800 is the de minimis threshold (no tax due on shipments that small). google usa customs de minimis.
- above $800 but below $1500: sometimes inspected depending on how the package looks and what it was declared as. what it's declared as matters because the contents are taxed accordingly. some things over $800 are not taxed at all.
- above $1500: almost always inspected.
if it's inspected, you're definitely going to have to pay tax if any is due. everything you need to know is here:
Harmonized Tariff Schedule
hts.usitc.gov
also, even if your shipment is assessed at 0% rate, you'll end up paying a Merchandise Processing Fee (MPF) if it gets inspected. plus a convenience fee of about 15usd to the courier.
Was going to get my wife a pair of them but couldn’t get them. Out of stock. Been a few months agoPruners
Got mine on Amazon.Was going to get my wife a pair of them but couldn’t get them. Out of stock. Been a few months ago
The insulated bit is specially built for "fastening" applications but not drilling LoL, right ? The reference/restriction to 7.2V drivers is probably from a torque perspective since insulated bits can only take much lesser torque (compared to regular all metallic bits) before shattering. If you use the insulated bit in a 12V driver AND reduce the torque settings on the driver, you should be fine as long as you dont try applying crazy force to tighten/loosen screws.
Just watched a bzeug video that reminded me about these insulated bits from Anex. I am thinking about trying one at work in a Bosch 12v driver. The bits are only recommended for drivers up to 7.2v, so it may not go very well.
Got me thinking, a plastic cased, cordless drill/driver should keep you insulated without the need for special bits, right?
Has anyone drilled into live mains? Does a plastic, cordless drill keep you insulated?
Yes they were out of stock. I was going to get them from another place but wasn’t going to pay 50%. I got her another pair.Got mine on Amazon.
I think we got a bit mixed up. Sorry if I was incoherent. I'm aware that it's a screwdriver bit.The insulated bit is specially built for "fastening" applications but not drilling LoL, right ? The reference/restriction to 7.2V drivers is probably from a torque perspective since insulated bits can only take much lesser torque (compared to regular all metallic bits) before shattering. If you use the insulated bit in a 12V driver AND reduce the torque settings on the driver, you should be fine as long as you dont try applying crazy force to tighten/loosen screws.
If you are not using the insulated bit and just want to go with all metallic bits for "fastening" applications, the plastic body and trigger of the drill will most definitely keep you insulated from 110-220V AC but i'm not too sure if the electronics within the drill will have sufficient protection to survive it ? Arc flash is a hazard (and FATAL) that could happen even at lower voltages if a live conductor makes contact with ground. Think of the risks of the bit slipping during such an activity and you could come in contact with the live conductors/components or the chuck of the drill. The risk is not worth the convenience/time saved. My suggestion - Don't risk it. Make sure you isolate the conductor before performing any fastening applications using a power tool with metal bits.
If you intend to really "Drill" into live mains conductors and not just use the drill to "fasten" screws etc, i would most certainly suggest you to refrain from such an experiment unless you disconnect the conductor/isolate it and ensure its dead before drilling into it. In this case too, Arc flash is a fatal hazard that could happen even at lower voltage levels if a live conductor makes contact with ground. My suggestion again - Don't risk it.
Sorry for the confusion. I was certainly aware that you knew its a screwdriver bit. I was trying a bit of irony in my question but please ignore that now. English is not my first language.I think we got a bit mixed up. Sorry if I was incoherent. I'm aware that it's a screwdriver bit.
Was just wondering if insulated bits provide any extra safety, and if they do, why they are they not more popular?
At work, it's up to 450-500V AC for power supply caps. We are supposed to discharge caps before removing components, but complacency/laziness means this is not always the case. Also, mistakes happen.
To answer your original question - Yes, the plastic body of a drill/driver will provide insulation at domestic voltage levels (110-220VAC) and probably even upto 450-500VAC.
Do insulated bits provide extra electrical safety ? - Absolutely yes, upto their rated voltage value.
Why are they not more popular - probably because of the fact that they are rated for much lower torque.
Would i use an insulated bit with a power tool on live electrical connections ? - No, i wouldn't. A cordless tool has no option to be grounded and hence has the potential for Arc flash occurring. A corded tool with a 3 pin plug (dedicated ground wire) is safer IMO. I wont mention Arc flash once again since i assume you're aware of the hazard but if you're not and you're working on electrical equipment, its worth a read.
Thanks for sharing, I just placed an order for the rotating handle one to try out.Pruners
