Cheapest 8kw load bank or appliance?
HamAndEggs
Houston, TX
I have a natural gas kit for my generator, and I need to tune the gas flow. But, I don't have any single thing that pulls 8kw...
Any good ideas other than trying to plug in space heaters, hair dryers etc and attempting to get them all controlled?
Walkers
Cave Creek Az
I made a load bank with a handful of water heater elements I mounted on the lid of a 55gallon drum then inserted them in the drum filled with water.
u2slow
BC
Two 4-5kw box heaters aren't a big deal. Or gang up as many free baseboard heaters as you can find.
TractorJeff
Elkhorn, WI
Long time ago a fellow needed a "Load Bank", I suggested Hot Water Heater Elements in a Barrel also. I think he figured out the cost and hassle to put it together, then bought a Fan cooled Commercial Jobsite Heater at a reasonable price. He calls it his "Summer Heater"!
MAD
Western MA
You could rent some stage lighting. There is a glut of 1kw Par64 cans out there now that LED fixtures are becoming the new norm. It should be pretty cheap to rent eight lights. Any real stage lighting place could set you up with what you needed to power/control them.
H
HamAndEggs
Houston, TX
I ended up finding an old Mitre saw I got for free in my closet, that paired with a space heater, old shopvac and my Skilsaw would get it to light the overlight light. I guess they have high inrush
I'm calling it good for NG tuning, what do you think? I think if it can run this without bogging down, I should be fine
dave*99
Coastal NJ
What model/brand natural gas conversion kit did you use? Can the generator still run on Gasoline?
Thanks
Dave
PCustoms
VT
I find it hard to believe that combo is even close to loading the generator.
What is the tuning process? Any voltage or frequency verification?
H
HamAndEggs
Houston, TX
I figure if its lighting the overload, that inrush must be pretty high
Just adjust the gas so it idles well, and is good under load. Its an inverter generator so the frequency and voltage is correct. I also used a tachometer to make sure the engine was at 3600rpm
mike93lx
Richmond, VA
Why does in rush matter? The tuning is for operation, right?
H
HamAndEggs
Houston, TX
During that inrush the generator ramps up but doesn't seem starved for fuel from what I can hear. So if it can handle that inrush, I would assume it should be fairly close to being in the right range for full load
mike93lx
Richmond, VA
But will you be running it at full load normally?
