AC freezing up from being set too low?
FMB4
I had the ac set to 71 and according to my fieldpiece temp meter it was keeping the shop at 69.5-70.0 degrees the entire time. The ac pretty much ran the entire time while it was 95 outside.
You are over-running your AC unit. Trying to keep your shop at ~ 70 when the ambient temps are 95 is not a good idea. Trying setting your thermostat to no lower than 78-80 degrees F. Note: your AC unit should never run "pretty much the entire time".
u3b3rg33k
:eek: Mine's run almost 400 hours this month. guess I better turn it off n suffer instead!
H
Hobby_Man22
tx
Once you start moving around and working on something 70 isn't all that cool anymore. I didn't pay $8K so I could sweat. Might as well shut it off and open the doors up.
  • Like
Reactions: Git
LS6 Tommy
Northern NJ
There is absolutely no reason to change the setpoint just because it's hot out.
Tommy
metlmunchr
The auxiliary drain pan should remain dry at all times regardless of the temp setpoint. If it doesn't, something is wrong with the primary drain line.
  • Like
Reactions: Git
H
Hobby_Man22
tx
It's still filling up. I blew out the trap this time. Am I supposed to be blowing air into the air handler too? I had an hvac guy tell me the trap is where it clogs 90 percent of the time, but I can still see water flowing, so it's not clogged.
H
Hobby_Man22
tx
Where do you see the water coming from that is in the pan, it may be a cracked condensate pan in the unit itself.
It's slowly dripping out of the bottom through the tape where the evaporator core is I believe. Like the last 4 inches from the edge of the unit. what are the chances of a cracked internal pan on something not even a year old?
H
Hobby_Man22
tx
Do you see water coming out the end of the pipe outside the house?
Yes it is. It's supposed to in this case. Usually it drains into a sink drain, but was plummed outside the building since it's a shop.
Wrench97
Southeastern Pa
If the drain pipe is clear and it's dripping chances are pretty good.
Terry D
St. Louis, MO.
You have a few choices, either call back who ever installed it. Call someone else to fix it or fix it yourself. Water should not be dripping in that safety pan under normal conditions. You will have to remove the covers and see what is going on. If your drain is not restricted, then I would look for a cracked pan, the pan not being installed correctly or possibly the wrong pan. We can not help fix this without pictures. To much airflow will also create problems
H
Hobby_Man22
tx
I'll have to take some pics. Now that I'm thinking about it the part it's dripping from isn't the actual unit itself, but just the ductwork. It was some insulated aluminum box that they made and attached to the air handler that extended it out about 2 more feet.
H
Hobby_Man22
tx
I can't remember if that part is insulated or not. I know the spiral ductwork is insulation. I just remember them folding it up to make it into a box that the spiral ductwork connects too.
Worsedog
Central FL
At work we installed a confiscated 5 ton in the horizontal configuration. It's first run was a disaster. Water leaked out of the fan access cover and if it ran long enough it would fill the cabinet and then the conduit for the power, it actually started to run out of the subpanel that powered it. We made a plexiglass cover so we could see inside it while it was running. You could see it sucking the water right off the evaporator. Some went all the way into the blower housing, but most of it fell into the bottom of the cabinet. We ended up running the fan one speed lower and that kept the water in the condensate tray rather than the airflow.
H
Hobby_Man22
tx
It's a slow drip out of the bottom where the tape is.
Worsedog
Central FL
That's the pan it's leaking into
See my post above, and also the others mentioning the condensate tray possibilities as well. If that tray is getting wet there is definitely problem in the box. As you said it is still cooling and seems to have good airflow, it's probably not freezing up.
Terry D
St. Louis, MO.
Can you post a picture of the whole unit. So we can see how it is installed. That picture is not showing much. Take a few pictures. We are trying to diagnose this over the internet
  • Like
Reactions: Git
H
Hobby_Man22
tx
Here's a few more.
H
Hobby_Man22
tx
Here's what's in the pan. Hardly that deep at all. Btw the unit shut off when I was up there taking pics and a good amount of water started a steady drip in like three different places out the bottom and into the pan pictured. I don't think it's a cracked internal pan. Probably just clogged inside.
H
Hobby_Man22
tx
Terry D
St. Louis, MO.
So it looks like the water is leaking out of the supply end of your air handler. Not the return end. The evaporator is at the retutn end where the drains are at. The pan in also in there under the evaporator. If it is pulling water all the way through the air handler and accumulating in the supply plenum. You need to have the installer out and check the cfm. To much air flow will pull the water off the coil. If it was a pan issue, it would be leaking at the other end
