I hope you don't have a 'Smart' meter.
good to see the drip-leg was done properly.
whats with the vent line from the regulator going into the ground?
2 questions, how does the solar power get to house after disconnect? I see no conduit. And why a 30 portable gennie circuit when you have the standby? Just in case?![]()
Ham, I sold Generac generators for a few years, and I was to caution you to make sure the generator exercises regularly. It should run once a week for 15-20 minutes. Run it during dinner, run it when you are generally home so you hear it. I can not tell you about the the number of customers that pay zero attention to the generator and then it fails and no back up.
We sold one to a guy with a million dollar home, he refused when we asked about an annual checkup and said he would call if he needed anything. Three years later he called as the generator would not start. I went out and found a bad starter solenoid. Funny thing is the generator had a couple hours of run time. It had failed 2 or 3 months after we installed it and he finally noticed!
Do yourself a favor and install a switch that breaks utility signal to the generator. Just a standard light switch, or a toggle rated for line voltage. Walk over, flip the switch, the genny starts and transfers. No need to keep tripping an expensive main breaker that really isn't made to be manually tripped regularly.Yep, the problem with their test is that its not loaded either. I will be installing Genmon soon so I can have a scheduled, loaded, test
I have it set to run on Sundays at 10am, non quiet test (As it seems thats pretty dumb)
Until I get genmon setup, I plan to just flip the disconnect myself every now and then and make sure it can take the load
Between 210 and 720 lives were lost as a direct or indirect result of this outage.I thought was pretty funny to stick on there
Smart meters allow the Utility company to reduce your power, and even shut it off completely, while still supplying full power to everyone else (or to those that 'matter' more than you do).How come? I have a smart meter
On my grid-tie photovoltaic system the inverter senses line voltage, and more importantly,line phase from the pole so as to match the phase on the outgoing power. If it sees no line power from the pole it simply won't power up at all and the solar panels are just big expensive sun shades on my roof instead of providing power in case of an outage. I've always wondered if applying power from a small generator would "wake up" the inverter thus allowing emergency power production while disconnected from the grid. Have you ever tried anything like that or did your installer mention anything of that sort?
Joe
They can shut your **** off without walking to your house or disconnecting lines. (Can't they? That was an attempt at poor humor.)How exactly do they 'reduce' power?
Some Co-ops can reduce load by shutting off power remotely to high usage items. Like water heaters and HVAC.Well, yes they can. I was referring to the ******** claim about 'reducing' power draw. That's a Facebook/chain email level amount of
misinformation.
Yep, but it can and does happen.The only way they would do that is with a voluntary program and smart switches
There is no way for them to do that from the meter. Power is power, there is no way to tell where its going from the meter and then shut down just that power
I have an Enphase system, has none of that stuff.For sure, from the left to right
* Enphase Combiner with Envoy - Brings my 4 x Solar AC Circuits and combines them into one, also monitors the solar
* 100a Solar Disconnect - Takes the power out the combiner and through a fused disconnect so you can shut it down
* Meter Box
* Main Panel - 200a main with feed through lugs which then run behind the wall to the house. Has 125a circuit for my garage sub (On the other side of the wall) and a 30a circuit for portable generator input
* Generac ATS - This is actually my "Main panel" Power comes in here from the meter (And solar since its a line side tap) and the 27kw standby generator, and then goes out to the panel to the left to supply power. If the power goes out, the generator starts itself and the ATS flips input power to it
Then at the bottom on the right is the 30a input for a portable generator
I agree most people have not signed up for the program that allows the utility to control individual loads in your home but some have for ACs and water heaters.How exactly do they 'reduce' power?
They absolutely do NOT have any ability to do this. A smart meter is still just a meter, it can't turn anything on or off. They do basically eliminate the need for someone to go around and read meters.Smart meters allow the Utility company to reduce your power, and even shut it off completely, while still supplying full power to everyone else (or to those that 'matter' more than you do).
May be the case for the brand of SMART meters your PoCo uses however the ones ours uses most definitely can shutoff the power. Ive seen them do it remotely for non-payment. No one has to come out to the house to pull the meter.They absolutely do NOT have any ability to do this. A smart meter is still just a meter, it can't turn anything on or off. They do basically eliminate the need for someone to go around and read meters.
Some utilities do have load shed programs. Around here the co-ops all do it with water heaters. It takes an additional switch wired to the water heater.
I'm not a lineman but I know several. The local guy still has to go out to pull meters for no payment.
