coats RC1 tire machine question
timm1
lagrangeville new york
I bought a coats rIt does not work for lawn tractor rims which are 6 to 10 inch. Is there different jaws I can buy for it so I can do small tires as well as a smaller duck piece?c1 tire machine which is for motor cycles and atv tires.
malbojah
Cape Cod, MA
Coats RC1??
RC100 (motorcycle setup)?
If yes, then different jaws can be made / purchased to get a bite on smaller diameter tire
T
timm1
I got jaws that clamp on to the jaws holder but the person did not know where to get a smaller duck piece so I can remove and mount a tire. Where can I get the smaller duck piece thanks.
T
timm1
I purchased smaller duck part. When you put a tire on I put the duck part on the rim and hole the tire down toward the center of the rim but when it is half way on the rim the duck part wants to ride on top of the tire and I use the tire lube. How do you prevent that thank you
