Air compressor volume question
gygeneral
Ontario, Canada
I have a single stage compressor rated at 18cfm @ 100psi. I want to get an HVLP spray gun, most guns need around 15CFM at 25-30psi. My question is, would my compressor still produce th rated CFM at 30PSI? I assume I would scale down the PSI at the gun with a regulator but what the CFM does at that pressure is stumping me.
Thanks
tboy
Central Ohio
I run the regulator on my compressor wide open (for me the tanks cycles around 125 psi) and regulate with a quality regulator at the gun. Line pressure to the gun is roughly 125 psi depending on the cycle of the compressor.
If your compressor can handle 18 cfm @ 100 psi it will have no trouble with 15 cfm at the gun
FMB4
Some sources say that you should multiply the required tool cfm by 1.5 (in your case this = 22.5 cfm) which your compressor should handle with ease. However, you have not mentioned the tank size of your A comp. The typical comp has a 20 gallon tank and if this is case with your unit then you'll be OK. If you're running a much smaller tank (i.e. a pancake, etc) then you may have problems.
G
gygeneral
Ontario, Canada
Thanks, my tank is a 60 gal tank, so it appears I'll be ok. I wasn't sure if the volume changes with the pressure.
mikedodge
To answer your question yes, at lower psi available cfm goes up a bit.
