Proto vs SK vs wright vs Williams USA vs Koken 1/4 sockets
12ptSocketsAreDumb
Hello everyone, I'm sure there's tons of existing discussion on sockets within the main industrial USA brands. However I don't see much comparison of the regular Koken sockets with these brands. Does anyone have any insight?
Notably the 8mm Koken 2400M-8 is about a $1.50 cheaper than the equivalent Wright Tool 20-08mm at circle c. The price is only about a 50¢ difference for the deep sockets.
I really like the z series but they're much more expensive in the deep drive than the other brands.
M6erfan
'Merica!
I agree with you on that honestly. I am just curious if theres any performance advantages of any single brand.
Proto, SK, & Wright are all pretty much equal, which is to say very good, IMO.
Ko-ken offers a few features that the three U.S. brands don't like shouldering & satin finish (on the lower part).
Mgdoug3
KY
I like SK so that's what I went with for the majority of my sockets. Proto and Wright are also high quality and I have a few of them. I may have to try some Koken sockets sometime. I happen to like using sockets with shoulders. I have an older set of Blackhawk and I think Challenger. I only use them for 12 point bolts but they're a lot easier to grab off a ratchet.
12ptSocketsAreDumb
Thank you for the response. What exactly do you mean by shouldering? Is it the groove that makes socket removal easier on the z-line? Notably the regular series doesn't have it. The existing koken regular line is a slight improvement over my old cman USA sockets for fitment.
12ptSocketsAreDumb
Thank you for your input. Notably only the z-line has shoulders on their sockets. The regular Koken sockets do not but they're significantly cheaper than anything else in this class. Only problem I've had with the koken z series 3/8 sockets is that they're actually too shallow. They often leave a small amount of the nut/bolt edge exposed due to how shallow they are. The z series deep sockets are awesome but I are pretty pricey since koken marks up their deep sockets quite a bit for some reason. I really wish they made a standard depth non-lowprofile z series socket.
81turbota
USA
I’ve grown accustomed to SO’s shallow broaching on deep sockets. My 1/4 SAE deeps are Protos, which are fantastic, but deep broaching meaning it’s difficult to use one to start a nut. Can be advantageous in some situations. Just something to be aware of.
SO left Proto right. Not a SO vs Proto battle just broaching style which vary manufacturer to manufacturer. Proto fit and finish is excellent.
12ptSocketsAreDumb
Very good point! This is one of the things I really like about the z-line koken sockets. I'd rather not have a deep broached socket again.
Does anyone know if the regular Koken sockets, wright, SK, or Williams deep sockets have shallow broaching like the snapons.
Mgdoug3
KY
Shallow broach sockets may be slightly stronger but sometimes a deep broach is handy. If you're in a tight spot, the deep broach allows the nut to move deeper in the socket. With a shallow broach, the socket gets pushed out.
12ptSocketsAreDumb
Fair point, though I rarely encounter these scenarios. Usually I just use deep drives to negate the need for extensions to reduce slop. Fortunately I have a few cman sockets as a backup.
mhejl
DFW Texas
I've noticed SO and Williams have an issue with "wobble-fix" style of extensions. I've had standard SO and SK wobble extensions in the past and just recently got some of the "fix" style Koken and SO.
The smaller 3/8 shallow (up to 13mm, 1/2") and all deeps have a broaching "mushroom" at the drive end preventing the sockets from seating completely on the "fix" portion of the extension.
I have some GearWrench mids that have a similar mushroom but the extensions seat properly. Same with Sunnex impacts.
Mgdoug3
KY
I have very few deep broached sockets as well. 95% of the time shallow broached sockets work great. I was only giving an example when deep broached might be handy.
12ptSocketsAreDumb
Does anyone have any comment on the likelihood of these to round off fasteners? I know the koken Z would likely perform the best but I am curious about the rest. I haven't found any comparison testing on these brands.
Mgdoug3
KY
A quality 6 point socket shouldn't round off any bolts unless the socket is completely worn out or the fastner is damaged or warn. I recently had a impact socket round off a nut because it was worn out. 12 point socket is a different story especially on smaller nuts.
12ptSocketsAreDumb
Only situation where I could see this being a problem would be on rust or undersized fasteners. Ive round a fastener or two when I lived in new england. Not really so much of an issue in the desert where I live now though I can't shake the mentality.
Considering your point, the socket life/longevity would be more important. I can't imagine any testing existing for something like this though.
bob15
Northeasten, CT
I wouldn't say that. They are all pretty much on par for being equal. I prefer the Wright over the ones mentioned (though I prefer Bonney the most). I like the larger numbers on the side of the Wright sockets and their tools have never let me down.
