What is this tool?
Mick56
Janesville Wisconsin
Picked this up the other day, Jones Mfg. Birmingham, Alabama. Their logo is a plumbing pipe trap. It is a ratcheting nut driver, but only goes one direction to tighten, and has that curved sleeve that swings out.
Mintgrun
Kingston, Wa.
It is a type of torque wrench. I picked one up in a third hand store recently and looked it up online. The one I found was marked 60 in. lbs. on the end where the logo is on yours. I think they might click at the prescribed torque setting. I have seen some online that have a square drive on the end like a socket wrench.
Here is a thread on them
Mick56
It is 5/16 hex, but I don't see any way to reverse the ratchet. It only tightens. I don't think it's a torque wrench, as much as I hold the shaft, there is no clicking.
archtimb
Looks like an older version of what we used to tighten no-hub fittings on cast iron pipes. Would click off when torqued to spec. Think of a no-hub fitting like a rubber fernco fitting wrapped in a metal sleeve.
Ricky Joe
Roanoke, Va.
Seekonk makes them. They are designed with a non adjustable preset torque value for specific applications. I have a six inch pound model made for Cummins engines that I use when setting valve lash. You may not be able to turn it because the torque value may be higher.
Mick56
At first I tried holding the shaft with pliers, but was unable to keep it from turning. Now I put a 5/16 head bolt in it and held the bolt with vise grips. I was now able to make the torque wrench work, but it took a lot of force to make the wrench skip.
Gear Wolf
Far out! What a neat tool!
Thanks for sharing this as well as those who helped expand on the topic by providing another thread! ^_^
