Gitter
Hello,
We're in upper Western Oregon, we bought fiberglass insulation for our pole barn/shop ceiling - by advice of our big box store's contractor desk, It gets cold out there in winter and we want it to hold heat better. There are threads on the internet and none we've read nails it down. I've done tons of research before asking The Garage Journal. I'm just hoping you could help?
Our pole barn is 40' x 48', the ceiling has 2"x6" rafters @ 24" apart. There are no soffit vents or attic space. We were told to put fiberglass insulation into the cavities, cover the ceiling with a vapor barrier.
We already have a condensation barrier of fiberglass insulation roll under the roofing that does the job very well. It's the kind with the white vinyl vapor barrier that look like a pillow from the underside. So putting insulation up from the inside and then a vapor barrier on the ceiling afterwards, would make it a double vapor barrier. Right, we do get that.
We've talked to people asking advice around and narrowed it down to a few ways. Some say to poke holes in the old vapor barrier and then go as planned with fiberglass and a vapor barrier on the inside of the ceiling.
Others say 'No' absolutely not! As heat rises up and through the holes it will condensate against the cold metal roofing and you'll get moisture build up like a glass of iced tea. Cold air could also settle downward through the holes and hit the warm air in the celling too and do the same.
Blown-in foam insulation's nice. But it's not practical or in the budget. And neither of us care for it much anyway.
Several have mentioned using Rockwool to insulate. Leave the existing insulation barrier alone, putting Rockwool up and having it open faced so it can breathe, not hold moisture and the vapor barrier will be in a more neutral zone - not so extreme. And that would keep moisture from entering the ceiling from outside as well, if the old barrier remained in place.
one of the most popular methods for buildings without pre-existing insulation is to use closed cel spray foam or foam sheets against the metal from the inside. Then tape, spray foam or caulk it up air tight,.. then insulate and a vapor barrier over that.
For us, we would need to remove the old condensation barrier first if we did that. And that's where I want to understand things better, if someone would be kind enough to help?
Why take down the old insulation with a vapor barrier, and replace it with closed cel foam to act as insulation and a vapor barrier? Or foam board and making it air tight as we can to keep moisture and air out, before we insulate, So, why do do all that if we already have something that does that now and serves the same function?
What do you guys and gals think? Any thoughts to offer? Can anyone help us see the light here? Has anyone had to do something similar to this with good results? Thanks for reading!
Winter is coming...
Winter is coming...
