I'm not sure why anyone would want to use refrigeration tubing but keep in mind if you use 1/2" or 3/4" ACR tubing you'll have to buy all your fittings from the HVAC supply house and also some of the typical fittings you may need like maybe a thread to a sweat might not even be available in ACR. The 1/2" and 3/4" fittings sold at the big box stores will not fit.
use garden hose
Not sure how i stumbled on this old thread but this post is sort of incorrect. ACR tubing is type L that has been nitrogen charged and plugged to keep moisture out for refrigeration use. Refrigeration 7/8" ACR, type L, even M etc. is 3/4" Plumbers. 3/4" inch "plumbers" has a OD of 7/8" same as the box stores 3/4". Refrigeration 5/8" is plumbers 1/2" size.
It might have been started a long ago but the information is still good for the many new guys who actually bother to use the search button.
New shops get built every day and having air is a good thing.
For those interested, PEX can also be used for air lines.
I've used it extensively. It works fairly well, though ordinary PEX isn't technically rated for air (PEX-Al-PEX is). The only place I have an issue is on my compressor drain. Something (might not even be the PEX though) seeps oil, and the PEX loop under my compressor is perpetually wet with oil. Not a big deal until it drips onto my drill press handle, so I keep a rag around there.I was going to ask if anyone ever used PEX but figured I would be laughed outta here. Now that the subject is open, I'm curious if you are serious or being humourous? It's hard to tell here sometimes.
By the way, I used copper in my shop. Been there for many years, sweated all joints myself.
I think it's also worth noting that most (all?) pex isn't UV resistant, so that should be considered when planning the runI've used it extensively. It works fairly well, though ordinary PEX isn't technically rated for air (PEX-Al-PEX is). The only place I have an issue is on my compressor drain. Something (might not even be the PEX though) seeps oil, and the PEX loop under my compressor is perpetually wet with oil. Not a big deal until it drips onto my drill press handle, so I keep a rag around there.
True (though PEX-Al-PEX should be ok). In my case, none of it is exposed to direct sunlight. It's either inside my garage (which has shaded polycarbonate panels over the glass windows so any light that enters is filtered, and I don't have any fluorescent lights either), buried in walls (I have a PEX air distribution within my house that I can charge with a hose reel on the side of my garage, designed for easy air tool use in the house as well as a way to blow out sprinkler lines), or a short run going to my sandblaster under an awning is wrapped in aluminum tape.I think it's also worth noting that most (all?) pex isn't UV resistant, so that should be considered when planning the run
Oetiker clamps. SharkBite is expensive, and really buys me nothing with air, so I couldn't imagine using it. It's ability to slip onto copper and quickly shut off a water line is a good selling point, but when everything's easily broken apart and threaded, why use a push-on connector?Crimped connections or SharkBite fittings?
Thanks. What size PEX did you use?True (though PEX-Al-PEX should be ok). In my case, none of it is exposed to direct sunlight. It's either inside my garage (which has shaded polycarbonate panels over the glass windows so any light that enters is filtered, and I don't have any fluorescent lights either), buried in walls (I have a PEX air distribution within my house that I can charge with a hose reel on the side of my garage, designed for easy air tool use in the house as well as a way to blow out sprinkler lines), or a short run going to my sandblaster under an awning is wrapped in aluminum tape.
I used 1/2" PEX for everything air related, with brass fittings. 1/2" will flow more air than pretty much any one of my tools can use.Thanks. What size PEX did you use?
Thanks again, I appreciate the info.I used 1/2" PEX for everything air related, with brass fittings. 1/2" will flow more air than pretty much any one of my tools can use.
Any time. I don't think it's possible to derail an 11 year old thread that's crept back from the dead several times already.Thanks again, I appreciate the info.
Sorry if I derailed the thread.
With a large enough budget, I would have used Copper; but I have a Harbor Freight air hose threaded through the trusses. The hose is working and it is paid for.
I would personally skip both the sharkbites and oetiker clamps and use upnor propex. The milwaukee tool is a little salty but you can either resell it and recoup all but 50 dollars of the purchase price or keep it for other product. Pex A tubing used for it is much better that B or C and the fitting don't choke flow like crimp fittings. Also there can be alot more moisture setting in a system with crimp fittings due to the smaller diameter.Thanks again, I appreciate the info.
Buying a propress machine to do a single air system is the epitome of garage journal. LolI would personally skip both the sharkbites and oetiker clamps and use upnor propex. The milwaukee tool is a little salty but you can either resell it and recoup all but 50 dollars of the purchase price or keep it for other product. Pex A tubing used for it is much better that B or C and the fitting don't choke flow like crimp fittings. Also there can be alot more moisture setting in a system with crimp fittings due to the smaller diameter.
and yes I will![]()
when i bought mine, it was 400 bucks. They were going 350 plus on ebay. 50 dollar long term rental is how I look at it.Buying a propress machine to do a single air system is the epitome of garage journal. Lol
I hadn't looked in a bit, so I was thinking over a grand.when i bought mine, it was 400 bucks. They were going 350 plus on ebay. 50 dollar long term rental is how I look at it.
I had never considered PEX, thanks for bringing it to my attention.
What is wrong with copper from a big box store? Plumbing supply is an alternativeI’m doing a smaller line run, basically from the garage into my office, probably about 10’ but I’m using this specifically for air brushing. I rules out black pipe, so not want the rusting but not sure where to buy copper, stainless, or even brass pipes? Looking online it can get costly with shipping. Any suggestions beyond a big box store?
Most hardware stores around us sell 10 ft lengths of copper.I’m doing a smaller line run, basically from the garage into my office, probably about 10’ but I’m using this specifically for air brushing. I rules out black pipe, so not want the rusting but not sure where to buy copper, stainless, or even brass pipes? Looking online it can get costly with shipping. Any suggestions beyond a big box store?
I was really interested in 316ss or even some brass, was looking at tube options but hard to find the pressure specs I need, wall thickness tends to be thin. Really wanted to have it all threaded just for easier install and to take down if I live within the next couple years. Might just have to **** it up in the costs, it’s not a long run by any means, 1/4” is plenty of air for my purposes.Most hardware stores around us sell 10 ft lengths of copper.
LOL there is more then 2, Copper would be expensive right now to run for air lines?Gettin ready to plumb the new shop for air, and wanna do it right the first time. Went to check prices on copper pipe, and didn't realize that there were 2 different types. Lowes had type M and Type L. Only difference I could tell was wall thickness. Question is, will the thinner stuff be ok for running compressed air lines? Any other suggestions?
For airbrushing you’ll be well under 100 psi. Thin wall and compression fittings (if you don’t want to solder) will be fine.I was really interested in 316ss or even some brass, was looking at tube options but hard to find the pressure specs I need, wall thickness tends to be thin. Really wanted to have it all threaded just for easier install and to take down if I live within the next couple years. Might just have to **** it up in the costs, it’s not a long run by any means, 1/4” is plenty of air for my purposes.
search challengedI am more curious why the question is asked about most old threads, and answered a 1000 times, and it is still brought up/answered by multiple people times.![]()
PVC is expensive right now too!Copper would be expensive right now to run for air lines?
