sill / concrete / sheathing / wall interface improvement
sofar
Southeast Wisconsin
As I build my garage I'm trying to solve 2 problems:
1. mice/water damage at the bottom of the sheathing that I'm fighting on my 30 year old house. It is some sort of asphalt impregnated fiberboard sheathing and is too close to grade, but plywood is going to rot eventually too. If you try to paint/seal/flash that bottom somehow then you could be pooling water above the seal. This is in wisconsin so occasionally you get 2' snow drifts sitting up against the house and the mice love that area.
2. I'd like to extend vinyl siding down over the concrete by 8" in some places. I put in a 16" block wall due to the slope and have 8" concrete exposed in some areas and 20" in others, and I'd rather not have quite so much concrete exposed for aesthetic reasons.
In the attached picture the first diagram is what I think is the traditional method.
The middle solution uses treated plywood near the bottom and keeps the vinyl siding 1/2" off the concrete, maybe that's enough to attach starter strip since that doesn't bear any weight. I would tapcon the plywood in at the bottom every 32" or so, but you will have a crevice there for bugs.
The one on the right moves the wall framing in 1/2" and lets the sheathing rest on top of the 2x6 treated sill plate. I like this solution the best, the only problem being that the siding is sitting directly against the concrete. I don't see how that will be a problem with vinyl siding despite some people saying not to do that, but if I ever wanted to put another kind of siding on that would be bad. I would use concrete nails or tapcons to put in the starter strip and maybe some adhesive so I don't have to put so many holes in the concrete. The second 2x4 plate allows me to easily build the 2x4 walls on a flat surface instead of putting 2x4 studs offset 1/2" into the treated 2x6.
Does everyone pretty much use the standard method and not worry about it until the bottom of the sheathing rots in 30 years? At that point you might be residing anyways and then you can re-sheath at the same time.
Bert_
NW Iowa
Just rip some treated plywood for the bottom 12" of wall otherwise like the first picture.
theoldwizard1
SE MI
Treated plywood or something like Hardi-board.
Get 2' wide coil stock and rub it from 1' above grade to 1' below grade BEHIND the treated plywood.
sofar
Southeast Wisconsin
Yes, if I wasn't trying to extend the siding down onto the concrete I think that is probably the best solution.
Simpler yet just bend an L out of coil stock to cover the edge.
That could work, you could fasten it outside of the sheathing and bend it towards the concrete so it doesn't get disintegrated by the treated sill plate. Hopefully it would be tight and uniform enough to the concrete to prevent mouse intrusion. I think fastening it to the sill plate and bending it outwards to the siding might work better, maybe painted aluminum would be fine, or you could put some barrier between the sill plate and the L. I considered some sort of metal bracket when working on my house but couldn't find anything premade with the right dimensions, but I wonder if some J channel with holes drilled into it for drainage would work.
And yes, I am WAY overthinking this.
jack stand
Lakes Region Maine
How about ;
Correcting any lower wall issues.
Covering and extending the siding with an accent colored vertical 4' metal "wainscott" ?
You'll have a flashing situation where the 2 meet, but that's nothing more than having the proper flashing bent up. There's typically a
