Identify Gray Steel work locker/cabinet?
1982fxr
Phoenix
Any idea what brand this is? I looked around but couldn't match it up.
FMB4
I can't answer you Q, but that cabinet should prove to be very useful.
1982fxr
Phoenix
Adrian, Durham and Sandusky make a lot of this type of stuff. I can't find any markings or stickers and don't see it when googling around.
The key code on the doors is k and then the numbers. Are codes company specific?
try entering your key code and the word "key" into google, sometimes they pop up with Gerstner etc in an ad for replacement keys. You might get lucky
1982fxr
Phoenix
Well I googled the code along with work locker cabinet and it seems like every company that ever made anything similar must have used that code because everybody came up.
So still no luck.
  • Like
Reactions: RTM
steaks&anvils
Colorado
The true secret to living with FSD is to always set things with the same height next to each other! That way you still have the same amount of flat surface area, it is just up higher!
