jeffmoss26
well done. I looked through my stuff and nothing for a lock marked '60' everything I have is a 3 digit code
Thanks @txlonghorn1989Uaiu You **** on the Atlast X-Y milling vise!
Thanks @3baygarage I’m having some trouble getting it to work right. It’s going to need to be disassembled I think.Username-nice find in the bullet handle.
Thanks. I have to answer, it was indeed! Based on several on-line sales, late 1950's and early 1960's Cavalier gentleman's bicycles have been selling in the $120 to $175 range, depending on condition.That bike looks great. I have to say, a sweet bargain Lugz.
Thanks @Shelbylex - The ratchet isn't frozen per se, but instead of easily rotating in either direction (which it will if I do it manually), it wants to just switch directions. I've got it soaking in penetrating oil right now. It seems to be loosening up. I'll try the ATF/acetone and see if that frees it up even more.Blackhawk rats - can you show close up pictures to see how far they went? If ATF does not help, you can try a very long but potentially useful way which I used a while ago on ratcheting 15mm wrench which I found in the mud (it was relatively good except that ratcheting part was stuck): heated it up couple of time on the stove with smoke coming out - no luck, all rusted... Started slowly soaking it in WD40 (small whack with a hammer on the moving part, spray and leaving it on a leveled surface (used plastic egg box and left it outside due to smell). After several days rusty drop appeared on the other side. Kept going for a week. a lot of rusty drops came out but now luck (well, that's what I thought). Gave up on it, started to disassemble the bicycle and decided to use the "stuck end" - well, I guess that was the last thing it needed - started working and still works...
NB I did not use evaporust as everything was black oxide on the moving parts - did not want to loose it ...
Both of the grinders I have now are pre-block round tops. The 1/3HP is a Delco made and the 1/4HP is Packard electric. So, the 1/4 can go away, I won't need them both. I'll post some pics over in the vintage forum in the block grinder thread.UNAIU,
Your donor 1/4hp grinder looks like a cast iron preblock? Possibly superior to the 1/3hp block, according to some. The amps are generally a better comparison than horses. I do not have a preblock to judge for myself. The couple I’ve seen at sales needed too much rehab to hook me. But if that one runs, maybe just use it?
For me "in the wild" means that I have seen in person with my own two eyes. Photos online or publications don't count.Along the lines of some of the existential discussions we've been having here lately...
Does "in the wild" have a universal definition here?
Does it mean something you've seen in person (even if you were alerted to it by a CL or other ad)?
Or, does it mean something that you tripped over at a garage (or other) sale, not knowing in advance that it would be there?
Or, something else entirely?
Mike
That should work well I've stopped using "cleaners/chemicals" directly in my USC, and use a second container with the nasty stuff; the USC tank gets water - clean water...I'd be tempted to put the frozen ratchet into a bath of oil (or ATF), and put that into an ultrasonic cleaner. Bad idea?
Mikr
I've always thought of it exactly the same Lugz.Great question. Speaking only for myself, "in the wild" means in person only (NO on-line presence), at any kind of second hand (not retail) sale (i.e., flea market, estate sale, yard sale, etc).
I'll be curious to see how much variance we get on this.
None of this matters, of course, because as soon as we get off this philosophical fugue state we're in, we'll all go back to using the same terms we prefer anyway, and politely, indifferently ignoring the ones we don't.That is why I think “in the wild” is a colorful but imperfect metaphor.
Snerk.Much like beating a dead horse is.
Here is one for the crowd to chew over.
Double snerk!will take me a few days to digest the purchase
For me it falls into the same category as visually picking through photos of lots of miscellaneous wrenches on eBay, as I described here...is this "found in the wild" or does the Offerup ad make it something different?
...which does come very close to making the "fleaBay" name that eBay sometimes erroneously gets more valid.That kind of online shopping (trolling through misc. wrench lots) - which I just don't have the time, patience, or beady eyes for, comes the closest to the experience of sifting through a pile of tools or a toolbox at a flea market or estate sale or garage sale.
Bonney flare nut combo wrench under the plastic toy wrench in the center? (or not, looks like a combo swivel now that I look closer)Who will be the first to identify the desired item?
The set of Allen wrenches is very nice, but I'm wondering about that skeletal combination wrench.So the question for the crowd: is this "found in the wild" or does the Offerup ad make it something different?
I think we're talking about the same one, only you used a much better, much more efficient word for it!but I'm wondering about that skeletal combination wrench
Even though it looks like pot metal, I'd pick up that combo wrench dead center with the high frame forging of the shank and the open end jaw head. For markings.
Haha. I'm okay with one image at a time. Photo after photo, for hours and hours (there ARE guys who do go through those kinds of eBay sales like that...), and they're more like this...And you say you lack the beady eyes for such image-peering?
I like it, p. It provides for a little more nuance on the margins. There are dealers at flea markets, for example, and buying from them there is not that much different than buying from them in their eBay store. Prices are lower, but it's pretty much a portable compilation of their inventory. So not everything at a flea market is in the wild. Conversely, those miscellaneous unidentifed wrench dumps on eBay. Yeah, it's online, not in person, but it's more like finding than buying from a dealer. So not everything online is, er, um, tamed.If you are shopping where the finders shop, it is in the wild. If you are buying from a dealer, it isn’t.
They're still out there! Easily 8 out of every 10 guys shopping at Collingswood are antique shop dealers or finders looking for things to sell to dealers. And everybody knows everyone else. It's the same faces every week. The toy guys, the LP guys, the watch and jewelry guys, etc. Collectors are few and far between, and because of that, they know us, too. Casual shoppers are almost nonexistent. Columbus is different. Lambertville is different, too. The ratio of collectors and casual shoppers is much higher. I think it's because of all the house liquidators/clearout guys at Collingswood. It's like a smorgasbord of estate sales in one place. Collingswood is some ********* picking.Back when my Mom was an antique dealer in the pre-internet era, there were “finders”. They were wholesalers of a sort. These were the guys (they were mostly guys) that went to weekly estate auctions, estate sales, tag sales, etc buying antiques to sell to dealers.
