rslaback
Years ago when I purchased a torch set I went with a portable unit instead of a full size tank cart deal because I wanted it to be portable. Having it be so has saved my bacon numerous times. However, swapping out MT and 20cu ft tanks is about the most expensive gas per volume that you can buy.
Recently I picked up a VarmitGetter to kill the gophers in my shop yard and with it I just procured a 80 cu ft oxygen tank. I am considering refilling my own torch oxygen bottles instead of swapping. The gopher blower upper uses LP so there is no plan to stop swapping out the acetylene tank (plus acetylene scares the **** out of me). The gas in the 80 cu ft oxygen tank is cheaper by volume than the 20. I know they make transfill adapters to do just this but was curious if anyone has experience doing this.
