WTF is this set of tools?
AlD
Here's something I couldn't resist at a yard sale yesterday. I couldn't find a maker's name, but there are numbers and angles on them--and they're nearly impossible to read. There are counterbores, and lots of other things, some with tapered shanks, some with straight. Utility knife in there for scale. Anyone ever seen something like this?
Thanks in advance.
Al
Provincial
Near Salem, OR
I see quite a few "counterbores." I'll explain why I put that in quotes:
Counterbores and spot facers are basically the same thing. The difference is their use. Counterbores are used to make a recessed area in a surface that is large enough to accommodate the head of a fastener (and sometimes, the tool to engage that head), while spot facers are used merely to make a spot square to the hole for the fastener to grip the surface with full contact, or something engaging or running on that surface to have a square surface of contact.
Counterbores generally have a radius ground in the corners to make a hole without a sharp corner. This is to avoid points of stress concentration that can lead to cracking.
Spot facers are often used on bosses that extend above a flat surface, and don't need the radius if the boss is smaller than the outside diameter of the tool.
I see that many of the "counterbores" have sharp corners, and would call them "spot facers."
That said, I would guess that these may be clock making tools. A second guess would be for making gauges or other instrumentation.
Provincial
Near Salem, OR
By the way, many of the counterbores/spot facers have pilots, which verify that they are used to squaring up surfaces associated with holes.
A
AlD
That is very helpful, and thank you for your thoughtful and intelligent reply!
Al
Those tools are usually watch /clock maker tools. That mount is fairly common in Jewelry maker catalogs.
A
AlD
That pretty much settles it. Thanks, guys!
A;
MShaw
York, Pa.
Just to clarify things the "counterbores" are used to cut a bushing down flush with the surface of a clock plate if the standard bushing is a bit too long.
