Tools you long for but can't justify
Iron Beaver
Leaflessshadetree
Don't ask.
Chainsaw for concrete (I can only think of 2 times that I could have used it).
Mag drill (I've never done a job that I could have even used it on).
Backhoe, bucket truck and dump truck (these I probably could use at least once per year).
ChevyEFI
Phoenix, AZ
A full puller set. A shop where I took a few classes had the full SO wall cabinet with full set. That's an incredibly appealing vision in a shop to me. For me, it carries over to other wall cabinets I see. Remember the Brunswick lane tool sets someone posted about? :) cabinets.
A lathe. I first used one in high school go turn a bat. I still use that bat when going to batting cages with my boys. Also, I have farmed a few small projects out, like grooving an output shaft for a lock ring, refinishing a welded journal etc. I would like to have the room for a larger lathe. And, threads are interesting. Cutting them is a bucket list thing. Abom on YT has at least one nice vid that goes over it.
tripplejl
Mainer
A car lift, a bigger garage to put in, a snap on epic to put front and center, a tig, mig, plasma cutter, monarch lathe, a Bridgeport mill, a dynomometer, airplane fuel scented air fresheners, side of fries and a shake..................... a big cup of coffee because I will need it after having such vivid polluted dreams.
PoorUB
Fargo, ND
I generally buy what I need, but I have self control and will not spend thousands of dollars for something really neat if I can't use it, or something else for much less will suffice.
GeoBruin
I have a full size *********** portaband and the smallest milwaukee portaband. I really, really, want the medium sized fuel portaband...
gatewaysysop
Arizona
If we're going with things you can't justify but can technically afford, I suppose I'd say a Bridgeport mill and or a decent vintage lathe. I'd like to get into machining things but there's just too much else to put the money towards right now, and I've got no real time to devote to a new and expensive hobby.
GeoBruin
A magnetic base drill. Like one of these.
Do you already have a conventional mag drill? I would have said a mag drill in response to this question a year ago but somehow I rationalized it and bought an hmd904 and I use it All. The. Time.
Indespensible.
zmotorsports
Northern Utah
I feel very blessed. Reading through most posts I found that I have a good portion of those. I wouldn't say I can't justify them however, as I actually use them.
One thing I would really like to acquire is a small scissor lift. I'm getting tired of going up and down a ladder to either polish the coach or work on things like slide toppers and awnings, etc. A scissor lift that I could drive alongside the coach when working on the roof line would be awesome but hard to justify. I've been keeping my eyes open for a used one but they're hard to find that aren't all clapped out or the people want as much as a new one.
LXCam
A CNC mill and an iron worker and the half dozen teeth I knocked out my head a couple years ago. Never gave much thought about teethes’s being tools till I needed to tear open a package the other day and ya know what?, they don’t put an edge on the fasley eye toof. What kind is BS is that?
