nadogail
Survived a workout session with my personal trainer; took so much energy I napped for about 90 minutes until lunch, after lunch made a bank deposit; now catching up with those who enjoy their garages,
We just replaced all the siding and trim on the chimney 2 months ago. I haven't seen any bugs while working on it, but will spray it just in case.You've got bugs in that trim. Get rid of the bugs and the birds leave.
That's good. Just keep healing.Nothing, and won't do anything heavy for a couple of weeks post eye surgery.
I finished moving everything to storage for about 6 weeks while the slab is removed and replaced, then quartz floor. Now that it is empty, I am standing in there trying to figure out if there is a better way to organize.
I've ruined a few pairs of jeans on an open primary very much like than when I was younger...
They can be used as 12v power supplies. Even an electrolysis tank. I sometimes use mine to run a 12v air compressor to fill those 8" hand truck and dump cart tires. Easier than dragging out the air hose and running the big compressor.I don't want to have a charger I need to put on a timer and take up my bench space.
When I grind my nails back in the shop, it usually involves skin loss/blood!3 coats of vanish on the first stair tread.
Ground my nails back to a reasonable length.
My ANC armored nails require a grinder. Mine is a Melody-Suzy. It has just enough gumption to grind finger nails. It can't break skin. I try not to stick my fingers in the bench grinder.When I grind my nails back in the shop, it usually involves skin loss/blood!![]()
I like to wear nitrile gloves when using bench grinder. Just enough protection to help with the occasional touch but weak enough not to pull your hand in.My ANC armored nails require a grinder. Mine is a Melody-Suzy. It has just enough gumption to grind finger nails. It can't break skin. I try not to stick my fingers in the bench grinder.
LED time.Averted a fire? T8 fixture decided to let the smoke out.
Wife left at 530 this morning, left garage inside lights on as usual. I left at 545 and smell electric burning smell. Then hear buzzing like a bee. Snoop around and see smoke from the tombstone end wafting to the ceiling and arcing. Remove bulb (which was still working) to find end charred.
Why did this happen? Fixtures are Leviton and about 6 years old and GE bulbs.![]()
Agreed…LED time.
Thx Kay!That's good. Just keep healing.
