Bridgeport Quill Downfeed Lever
paulsomlo
Northern Colorado
Can anyone tell me how the pin is supposed to be retained in the handle? Admittedly, I don't know that this is the original pin.Webp.net-compress-image (5).jpg
P
paulsomlo
Northern Colorado
I don't actually own a Bport - I got two of these handles in an auction lot and same story with both of them - I can't figure out how the hidden end of the pin retains in the handle.
Grant Gunderson
Bellingham, WA
My first photo above shows the pin properly installed. It’s the fulcrum for the lever. Here is a shot with the cover off.
here is a shot with the handle removed and the lock pin in its T slot.
P
paulsomlo
Northern Colorado
Ah... thank you very much Grant - the pin I'm referring to is the lock pin, but my handles both have circular cross sections, rather than rectangular. Each one has a small blind hole, rather than a t slot. I'm at a loss as to how the lock pin was retained in the movable part - I don't think press fit, because it needs to pivot slightly.
Grant Gunderson
Bellingham, WA
Is that lock pin tapered? That would keep it from falling out and then no need for it to be attached to the lever arm.
looking at your photo it looks like the hole that holds the pin in the handle has become elongated so it most likely originally was a press fit. Does the pivot hole in the handle have enough slop for it too still work if it was pressed in?
regardless the handles are so cheap it’s probably not worth much effort to fix if it’s not a simple press fit or tapper pin.
P
paulsomlo
Northern Colorado
Nope, measures about 0.187 at either end, but I don't think it's the original pin.
Tapering would keep it from falling out, but what would enable it to retract when repositioning the handle?
bugnut
Central Ohio
comparing Grant handle to the OP post is it possible the spring provides enough tension to hold the pin in place? And then stake the ends of the pin, Also noted is that Grants first image is a roll pin not a straight dowel. just thinking outloud....
P
paulsomlo
Northern Colorado
The pivot hole measures about 0.191, so pretty close. I'm assuming the Bport accepts a 0.187 pin. I suppose I could ask over on practicalmachinist.com, some over there will have the same style handle.
The pin I'm referring to is the one that engages the mill.
no704
I’ve seen lots that just sit there, not retained by anything, have to be careful not to loose it!
