I think I have finally settled on the lift I wish to purchase for the garage I am having built. Advantage Lifts dx-9000xlt.
Issue is I just got concrete poured Tuesday, so obviously, can't place much weight on it for a while. That said, the prices and availability of these lifts isn't going down, well maybe the availability. They told me a few weeks ago they had 5 or 6 local to me, I can buy and pick up whenever. Builder says he'll start standing walls next week, so then we can get lift whenever and he'll work around it to hang trusses. He seems willing to maybe help me go pick it up as I need an 18' trailer(preferable) to move it.
Here's the deal, I don't mind doing that, but if he gets held up on the trusses or sheeting, how long can I plan on leaving the lift semi exposed to elements even if I leave it in the crate and tarp it? I'm not worried about it walking off, but I do worry about sitting on an unopened crate. I'll likely hold off on picking it up until he moves further along, but I also don't know how long they are actually willing to sit on it. *to add to the mix, I was referred a lift salesman through an acquaintance. I looked him up and let's just say there were tons and tons of complaints against the company he seemed to be in charge of but they were years and years ago. Still, won't use him, but it makes me a bit nervous about not immediately taking ownership and installing in case there are issues. I plan on buying through my AMEX card, so I should have some coverage if things go south. I just don't want to wait and then not being able to get the lift I want for 6 months or so and prices going up again.
Does anyone have any recent experience or feedback? Am I crazy for buying it now and waiting?
As for the wheel dolly question....I plan on buying a set of 4 dollies. I really like the ones that you slide under and jack up with foot or by hand, but curious if I should plan on getting a set of each style? Are there pros and cons on both? I've watched video of them unloading the lift with a cherry picker and a set of the standard dolly that you jack the car up on and then lower. Basically, they lift the crate up on the tongue end of trailer with the picker, slide a dolly under, then lower. They then jack up on opposite end, but slowly pull trailer out. The tongue end rolls on the dolly toward the end of trailer, then then let the crate down on the 2nd dolly, which is now on the slab. They then jack up the end still on trailer, pull out the trailer, lower down the 1st dolly which is now on the slab and you can then wheel the entire setup around for unpackaging. Should this work for the hydraulic ones? The other issue is most I see, both styles, are 1500lb capacity each. I thought I read the standard 4 post lift is 3500lbs....I'm buying the xl lift, with extra height clearance.
