KnurledNut
Ive seen drawers fail, but anyone know of casters giving out and a whole box falling over, etc?
I was in Horrible Fright one day & a guy coming towards me had his entire shopping cart collapse. I mentioned that they probably bought the shopping carts of Horrible Fright....I saw a cheap Harbor Freight cart disintegrate because of and over loaded tool box on it. Very loud. Jim
I started this thread -in part- because of this very same box!Yes, a machinist bottom kennedy, the owner had probably 800 lbs of steel and brass offcuts in the bottom 3 drawers.
What on earth?!I was in Horrible Fright one day & a guy coming towards me had his entire shopping cart collapse. I mentioned that they probably bought the shopping carts of Horrible Fright....
No it was years ago, pretty sure its now resides in a chinese ratchet or somethingI started this thread -in part- because of this very same box!
I recently passed on buying one because the casters were not very convincing. (And the key was missing.) It was hard to pass up otherwise, as it was a great deal.
Edit: Hey Firebrick, he didnt happen to sell this box recently, did he???
jack or well cut 2x4s under that drawer that we cant see? Or do you weight under a buck fifty?
No shenanigans. I’m 6’0” and a little under 200lbs.jack or well cut 2x4s under that drawer that we cant see? Or do you weight under a buck fifty?
I had a Lowes plastic cart blow through with 800lbs of concrete.I was in Horrible Fright one day & a guy coming towards me had his entire shopping cart collapse. I mentioned that they probably bought the shopping carts of Horrible Fright....
I know a really large guy - we call him Slim. He sat on a tool cabinet and ker-blam! Down she goes. It was a Craftsman box.Ive seen drawers fail, but anyone know of casters giving out and a whole box falling over, etc?
My US General 5 drawer cart has bent at the caster mounting points and is starting to tear in that area. It's very overloaded so that's my fault. I think it would have done better had it spring loaded casters.Ive seen drawers fail, but anyone know of casters giving out and a whole box falling over, etc?
Tipping a toolbox over is only a fail if you arent able to get the tool you were originally after.I've see a couple tip over from guys opening too many loaded drawers at the same time. Mine has even tried to do that but I was able to shove a drawer closed.
30,000 caster fail. "Oh no, oh no, oh no no no no no..."
I’d hate to **** up a perfectly good dump truck.They should do that with six US General boxes!![]()
I2've seen a couple stacked models tip over when a caster failed. In a typical USAF vehicle maintenance shop the boxes get moved a lot. Not many technicians have a designated work spot where the box gets parked for years. The only ones I've seen fail were from non-suspension (cheapo stamped casters like you see on older CM or HF style boxes) boxes, loaded too top heavy, moving, and catching a crack or hitting an object just right. Even better when the box isn't locked so the drawers start sliding out on the way over and get f'd up too. A couple single rollers have also had casters fall apart in similar fashion, but not tip over...mainly because they're too deep, too close to the floor, and not enough mass to keep them tipping.
Edit: I should also mention many shops back in the day had 25" CM triple stacks. They were not the most stable boxes to begin with, let alone drag all over a shop day in day out.
I also saw many boxes tipped over, backed in to, and smashed by careless knuckleheads over the years. I don't have the pic anymore, but one shop a friend was assigned at had a toolbox speared by a hydraulic ram.
V/R
Bogie
I've seen a couple stacked models tip over
Back in the early 1980s I worked at a garage that had two levels. When you had to change levels they moved your box with a forklift. I had a Snap-On Taco box with a top box. It slid off of the forks to the side, balanced for a second, came down on the wheels, spun 180 degrees, and rolled down the hill square into the grill of a Freightliner. It racked the top box and severely damaged the bottom box. The company bought me another box.
Working industrial maintenance I bought a stainless husky box. The one with 5 drawers and the side door cabinet. I don't recall what it was rated for but after putting all of my 3/4 drive stuff in it you could tell it was crying. A month later after being pushed around the shop on of the rotating casters gave up the ghost. It's now in my garage with some industrial casters on it. Still crying from being full of tools but it's still much less weight. To be fair to the box I am 100% certain nobody at the home depot thought a 5" 3/4 drive socket was going to grace the drawers of this box, much less fill the box with those size of tools.
