Jawn
I have an old Lincoln IdealArc 250/250 (probably 1970s vintage) that I'd like to hook up in a new detached garage/workshop at my house. Plenty of anecdotal evidence of these running on normal 50A welder circuits at lower power settings, but I'd like to have this thing hooked up "right" in my new workshop.
Local (GA) code is NEC 2020 and inspections will occur as there is a new service being installed.
It's a little vague on its specifications, the manual has a table which assumes 200A secondary current even though it's a 250 amp welder. At 200 amps secondary, the primary is stated to be 70A and 50% duty cycle. It also specifies a 90A "superlag" fuse... not sure how to correlate that to a suitable breaker.
I can work from the 70A at 50% duty cycle to get that I need conductors sized for 49.7A (using .71 multiplier from 630.11(a)), but overcurrent protection I'm a little less sure of. Am I interpreting this correctly that 630.12(A) says overcurrent protection cannot exceed 200% of that 70A? So... 140A? Seems crazy high. Or is it not that critical, so long as it's under that 200% and big enough to not nuisance trip? What size breaker should I choose?
