Yah, it's an odd duck. It's certainly old. I wonder if the ones with "patent ***" on the end caps are older? Sure wish somebody had done a study on EstwingI've never seen a green Estwing. Only own 3 or 4, but seen dozens.
Anything is possible but I thought Estwing were always polished steel, only now is paint becoming common on new hammers they make to cut costs. I would expect the green was someone's tool identification colour.Yah, it's an odd duck. It's certainly old. I wonder if the ones with "patent ***" on the end caps are older? Sure wish somebody had done a study on Estwing
Dang. I like that level of organization. The dividers to hold things loosely upright is great.Here is my drawer of loud poundy things.
Yeah thanks! It works out pretty slick tbh. I figured any more then 2 in same slot and it could be a domino effect?Dang. I like that level of organization. The dividers to hold things loosely upright is great.
That'll buff right out.turns out there’s a crack in the steel from the stamp around past halfway agross the ball
When painting hammers, I try not to apply the paint too thick. For whatever reason, the paint seems to stand up to abuse better when it's thin.You gentlemen who paint a hammer when you restore it, what type of paint do you use on it? Is there something special?
I decided I wanted to tackle a couple of cheap chinese hammer heads I was given. Last night I got carried away with the grinder on the 8 oz. ball pein. I was pleased with the way the replacement handle turned out with just some 220 grit and a coating of tung oil, though.
I need to figure out a better way to get the rust off of the 4# sledge without removing the shape of the hammer and all its markings like I did on the ball pein with the bench grinder. I think I'll start with a vinegar bath and see where we go from there.
Always great to see some rubber mallets. I use rubber mallets all the time.
Is the tool, on the right side of the picture, a breaker bar? Also... did you make those sockets?
That is a beautiful handle.I adopted this pitiful, orphaned Vaughan CF1.
Busted handle, rust and varnish, the new ugly painted logo that replaced the older beautiful stamped version....poor child begging for TLC.
Started with an orthopedic transplant...
...combined with a much needed dermatopathologist topo-surgical procedure.
Followed up repeatedly with the dermatologist...
The meds and microdermabrasion seem to be working...
After some time and healing, a child knows when its loved.
