Finallygotit
Progress is progress, still looking good. What floor epoxy did you go with?
JB
Hey JB, I went with Rustoleum's Epoxy Shield for the base coat.
For the clear coat I went again with Rustoleum's Epoxy Shield.
The clear coat comes in a new two part burstable pouch. You start rolling one pouch until it builds enough pressure and it breaks the seal between the two then you start kneading. From the reviews I saw about it, I was not going to go that route as they stated that the mixing was incomplete. So I cut down the middle of the separating seal, cut the corners to open the pouches and poured it into a plastic bucket to mix. I also added the silica sand non-slip additive while I was mixing. Worked out real well.
Floor looks nice Dan!
Thanks Marc and thanks for stopping by!
