The problem is that the machine that does the stamping was designed by a group of engineers that have never used a drill bit and it would cost millions to change the assembly line and machineryMaybe print or stamp the size higher up on the shank so the chuck doesn't ruin it right away?
A$$holes.
...engineers that have never used a drill bit... You forgot to type the / character at the end of your comment.The problem is that the machine that does the stamping was designed by a group of engineers that have never used a drill bit...
I'm an engineer, and I have also wondered why they stamp them in the location they do.
I really like the bits with three flats, no spinning that way.
thank you for the explanation. Question, though, why not stamp the size first, before heat treat?Drill bits are differentially heat treated so that the cutting end and the flutes are hard and the shank, well yeah that's hard too but not AS hard. This is for better chuck grip and for allowing roll stamping.
The problem is, the closer you get to the flutes the harder the material. It's not a huge differential, but enough that roll stamping becomes impossible. (think about the act of stamping and leaving an indented shape and how that might become more difficult on material harder than a tooling die or just willing to shatter from pressure).
Drill bits are not heat treated after forming into a drill bit. They are precision ground after heat treat to their final size, otherwise the final size would not be accurate and you'd risk warping (causing run-out or wobbling) or chips from handing or cracks. Which is why it's so costly to make good drill bits, takes awhile to grind into hardened M2 or cobalt.thank you for the explanation. Question, though, why not stamp the size first, before heat treat?
Power the chuck closed to a point smaller than the drill, the reverse the drill and power open until the drill slides in to the chuck and tighten.What percentage of the time does the chuck grab at the correct spot (on the flats) for you? Mine seems to be about 1/4 times it needs adjustment!
every time. You need to set there and wiggle it as you tighten the chuck so it sets perpendicular to the flat. As for the stamping being torn up, good chucks don't slip. Replace it with a good rohm.What percentage of the time does the chuck grab at the correct spot (on the flats) for you? Mine seems to be about 1/4 times it needs adjustment!
That makes perfect sense. Thank you for the clear explanation (and also for making nice tools!)Drill bits are not heat treated after forming into a drill bit. They are precision ground after heat treat to their final size, otherwise the final size would not be accurate and you'd risk warping (causing run-out or wobbling) or chips from handing or cracks. Which is why it's so costly to make good drill bits, takes awhile to grind into hardened M2 or cobalt.
That's not to say that there aren't some processes done to drill bits after with a wide range of options. But for the most part the material is incredibly hard when brought to the machine shop floor.
Put me in this category. If a bit is in question then the calipers come out. I end up with a lot of used bits and once in a while I set up a session at the drill bit sharpener and sharpen, then measure to determine the size. Once the size is determined the bit is put put in the proper place whether it be an index or drawer. If you understand that drill bits are not for making precision holes then life becomes easier.I have fraction drills, numbered drills, lettered drills, metric drills. Often they are so close it is difficult to tell them apart with a plate gauge. If they didn’t have a different appearance due to different manufacturers it would be hard to get them put away sometimes.
My most commonly used drills all have some scarring on the shank. They usually get replaced once a year or so. I always have calipers around if I am unsure, or need to find a specific size in the box of used spares. I have a loupe in the toolbox to read the sizes if they have them. For anything over 3/16“ or so an end stamp would be ideal.
