My drainage needs a cleaning every 2 years or so. Previously I always rented a Home Depot 75 ft drain snake and it worked well for me. The only problem is that each rental cost me about $60, which is pretty unpleasant and there is a four hour time limit. I constantly feel under pressure.
So this time, I borrowed a neighbor's Brasscraft drain snake.
It did not work very well. The neighbor is not good as maintaining the tool. There is a lot of rust in the drain snake and it won't go forward unless I pull on it. So it turned out to be a quite struggle. And it did not clean out the drainage like the HD rental did before.
So my choice now is either to rent again, or to buy the HF one.
www.harborfreight.com
I am wondering how good is the drain snake relative to the HD rental? And how long can it last before it rusts away? There is also a guy selling this hydrostar on CL for $150. Is it too risky to buy this kind of stuff used? Thanks for the advice!
I am also interested in learning how drain snake works. If I want the snake to go forward, should I tighten or remove the thumb screw near the cable outlet?
BrassCraft BC260 .31-Inch by 50-Feet Cable Drum Machine - Faucet Trim Kits - Amazon.com
www.amazon.com
Harbor Freight Tools – Quality Tools at Discount Prices Since 1977
Harbor Freight buys their top quality tools from the same factories that supply our competitors. We cut out the middleman and pass the savings to you!
