I've already got Duro as a NO. What about Plomb 4766? I don't have one to check. That one will be interesting, because the WF-7 (9/32-drive, USAAF production) had the detent.
Well, I knew this would be like herding cats, but I didn't think it would be like herding cats right out of the gate by two guys who are normally very good at following directions!!
Thanks, J, and cool set (I have a very similar Super Chrome ATHOL set made by Heath & Pond, see post #616) but it also has no hinge handle whatsoever, and if there is no hinge handle, it's outside the parameters of my interest.
And some crossbars also just have a little pinch in the bar on one end, which also creates a stop, preventing it from sliding out in that direction. But none of the crossbars in the interchangeable era are captive (two balls, two pinches) and crossbars with one detent ball or one pinch can fall out the other way.
However, I am not interested in an exhaustive list of 'Ways in which Mfgrs Kept Crossbars in a Crossdrilled Hinge Handle holes.'
I'm only interested in answering this question: Which Mfgrs put spring-loaded detent balls in the crossbar holes of their midget drive hinge handles? I suppose I could've just asked it like that, but open-ended question usually prompt vague results.
Thanks for your input. I edited the running list in post #1,469.
, this project brings this quote to mind.. ha ha..
Thank you! That is VERY helpful.Wf yes, 4766 no. My early snap on 9/32 no, williams 9/32 yes, armstrong yes, herbrand no
Thanks.I've never seen any Indestro brand breaker (2850) with any detent ball in the handle (and I have quite a few of them.)
Thanks.Other than that picture, I would say that they don’t exist. My only original Plomb crossbar does NOT have the groove and none of my 1/4” drive Plomb handles have the balls, so I’m saying no on 1/4” drive Plomb.
Sorry, but I'm not following you on Einstein's caution, J, as it relates to empirical surveys, many of which I have conducted before, in general, or on my insistence on constraining this one to my focused purpose, which is just common best survey practices. EDIT: But if you want to start a broader one on other crossbar retention techniques, or on sets without hinge handles, I would support you!Beware,, this project brings this quote to mind.. ha ha
I was just trying an attempt at a joke Lugz.. I often find the humour of Einstein amusing and somehow comforting..Sorry, but I'm not following you on Einstein's caution, J, as it relates to empirical surveys, many of which I have conducted before, in general, or on my insistence on constraining this one to my focused purpose, which is just common best survey practices. EDIT: But if you want to start a broader one on other crossbar retention techniques, or on sets without hinge handles, I would support you!![]()
It's remarkable how someone responsible for such a monumental discovery was so self-effacing and whimsical.I often find the humour of Einstein amusing and somehow comforting
Not surprising, as the organized mind often sees the folly and whimsy in the world. Add the analytical to the organized, and it is a path to humor! Or madness.It's remarkable how someone responsible for such a monumental discovery was so self-effacing and whimsical.
Yes, as I noted in my list here...It has the detent on the opposite side of the hole from snap-on...
What Plomb did was forge it, mill it from the end above the crossdrilled hole, just like SO, but then mill below the crossdrilled hole and seat the spring and ball inside that. It remains open at the end, ostensibly to access the ball and spring, in case of repair or replacement, but practically, probably just because it was more economical.Plomb WF-7 (9/32) - YES - bottom of hole
Yes, into the 50's actually, but mainly for military or special industrial (aircraft industry). I don't think anyone was advertising it commercially after WWII.Were there not several other manufacturers of hand tools still making 9/32" well into the 1940s?
Craftsman BE - NO
Craftsman (H) - NO
As I am unfamiliar with Blackhawk of that vintage, are those 1/4” drive? Did Blackhawk offer 9/32” drive at some point?
Yes. Thanks.Lugz, is this the Midget thread you mentioned moving the conversation to, from the Snappy thread?
In a purely commercial context, in which the manufacturer has control over all variables and the product, as a purely mathematical cost-benefit exercise, of course I agree. And I appreciate your expertise in that. But the context - what started this whole expanded excursion over here on this thread from the Snappy thread, was the fact that Snap-on was making hinge handles with and without detent balls, at the same time, during WWII, for military customers. That's why all those factors are anything but irrelevant. Hence my reply.In short, cost/profit/laziness is a dependant variable, whereas available time, labor, equipment and material are independent variables, each of which may be the actual reason why the 1/4dr has no detent, OR why the 9/32dr does have a detent (as was pointed out, those are two different questions). Linear programing can be used to calculate a product mix of 1/4dr and 9/32dr hinge handles which optimizes for expediency, profit, cost-savings, etc,
I am still looking into it, but the results of the survey (#1469, page 37) and the conclusions I had already drawn from it and summarized on the Snap-on thread, prior to your reply about manufacturing optimization and wartime urgency, already eliminate the idea that cost-savings and faster schedule had anything to do with this particular case.There may, in fact, be other reasons why, that have nothing to do with manufacturing concerns (as I think you are considering, ie customer specs).
See reply just above.As far as “the War demanded urgency,” I am making NO claim that urgency affected 1/4dr and 9/32dr handles separately. The limited nature of available resources dictates that production of BOTH products are affected. Reasonable assumptions about those resources seem to me to suggest that many more detent-less (1/4dr, as far as we know) tools could be produced by a given deadline, than detent-bearing (9/32dr) tools, but as long as BOTH products were manufatured in a given period, the total number produced of each was significantly reduced from the maximum possible separately.
Yes.are those 1/4” drive?
Not that I know of.Did Blackhawk offer 9/32” drive at some point?
