Musky_Hunter
- Joined
- Sep 20, 2021
- Messages
- 117
That's kind of what I was thinking. I am not going to be building to aerospace tolerances. Just don't want to be getting into a machine that is going to need a ton of work. About the biggest thing I would be doing is resurfacing some 3cyl exhaust manifolds for old Ford tractors.The hand scraping is worn way about 1-2 inches from the end of the ways. This is the most used part of the machine. There are some gouges but honestly if this is your first machine and this is just a hobby I probably wouldn’t worry about it. You will not be sending anyone to the moon, but if the rest of the machine checks out you will most likely be fine. Your second machine can be better once you know what you are doing.
Asking 2500 for the mill with DRO.I’ve see many machines where no flaking is visible at all anywhere on the ways. And that is after you wipe all of the grit and chips and grime away. That honestly doesn’t look as bad as most used machines. What is he asking?
I’d probably buy it for that.Asking 2500 for the mill with DRO.
I definitely would, mine was £3,600 plus transport costs, about $5000 by the time I got it home and it doesn't have a DRO, but they tend to be expensive here, until about 15 years ago you could send any complete Bridgeport back to the factory no matter how worn and they would give you £1,200 ish just for the castings for rebuildingI’d probably buy it for that.
I think its generally a good Idea to replace the wipers on any second hand machine, I am yet to buy any used machine that didn't really need a set, the holders for the wipers shouldn't be too costly or hard to get and the wipers themselves are cheap.The dings in the working ways are not a problem IF they have been stoned down so they do not raise a high spot around them that interferes with the upper part of the way that passes over them. I would be more concerned with the missing way wipers that keep 'stuff' from getting under the saddle.
lg
no neat sig line
