Musky_Hunter
- Joined
- Sep 20, 2021
- Messages
- 117
I did it using some delrin strips that were 5" and 48" long. I was able to crib the mill up to get the delrin under it. After that is slid pretty easy. Moved it about 20ft that way.You moved a milling machine by yourself?![]()
That's exactly how I moved my four post lift ramps into place. It worked well.I did it using some delrin strips that were 5" and 48" long. I was able to crib the mill up to get the delrin under it. After that is slid pretty easy. Moved it about 20ft that way.
That is a great idea. Place looks good!I did it using some delrin strips that were 5" and 48" long. I was able to crib the mill up to get the delrin under it. After that is slid pretty easy. Moved it about 20ft that way.
