Vintage Elgin cockpit clock
matt stott
Boston, USA
I have had this old Elgin cockpit/tank clock on my workbench for years now. Finally decided to dig in to it and see if I cant get her ticking again. Figure if I can fix a lawnmower I can fix this!
i think the dial on this one has aged really well- it has age- but in a way that looks really cool. Anyway, back to cleaning all the pieces parts.
matt stott
Boston, USA
Got it mostly back together last night-- and onto the timer. So far, losing about 2 sec/day in all positions: not bad, considering I had to do some serious reshaping of the balance hairspring. Still some work to do to get the beat error better and amplitude up a bit, but all the major parts are working as they should. I will probably case it back up this weekend- no restoration, only the usual cleaning and oiling- and replacing the mainspring.
Matt
rlitman
Long Island
Should take the time to read "The Radium Girls" by Kate Moore...very haunting tale of how so many young girls were destroyed by their work for the war effort, and how the companies tried to make it go away.
War effort? Not remotely. Heck, their cases were all settled before we entered WWII. This was simply private enterprise taking advantage of employees before the days of OSHA.
matt stott
Boston, USA
Thanks for the book recommendation cvair- I had seen that book before, but never picked it up- definitely going to read it now.
All cased up and ticking well now- i need a new gasket for the glass, you can see it is broken, and a new spring clip for the glass too. The one in there now is shot. I think i am going to use some BrassBlack on the panel mounting screws, too. Way too shiny there (but it does look nice sitting on my Harry Epstein leather weight!) Now I just need to figure out a place to mount it in my shop, or maybe make it into a desk clock type of thing.
driftpin
I read that awhile ago, it's now in my library. That and The Jungle by Upton Sinclair make great reasons why organized labor came into-being.
The O.P. seems like his work has borne fruit. A good job on the clock.
Provincial
Near Salem, OR
That same type of clock was original equipment on my 1953 Cessna 180. I kept it when I updated the instrument panel to modern instruments and radios because I liked it.
Cessna, and other light aircraft manufacturers, used many WWII-era instruments and gauges for a number of years after the war. Probably because they were dirt cheap! By the mid-1950's more stylish and compact instruments were being introduced, and they were adopted in new aircraft.
rlitman
Long Island
They also used car parts like door handles and window cranks. That clock was made to fit in an WWII era aircraft (many types), but actually was used in car dashes before the war (with a prettier bezel, but not all that different inside).
Provincial
Near Salem, OR
I think Elgin had been making clocks for aircraft instrument panels since WWI, and for sure the early 1920's. The Army was a strong customer, and I'm sure the Navy as well. It makes sense that the movement was also used for automobiles, which would amortize the costs of tooling over the largest number of products. I don't believe that military specifications for these clocks was tighter than for civilian general usage, since the military was big on synchronizing clocks and watches as an operational procedure.
The case is one of the cheaper components of the clock, and molded plastic cases were acceptable. The dial and hands (especially the radium) were an important part of the military specification.
Sumboodie
AK
Elgin like the company that makes street sweepers?
Odd it's not a 24hr clock
Provincial
Near Salem, OR
The military did have specs for some 24-hr clocks, but in general use the standard clocks were adequate. A 24-hr clock with a display to easily read the one minute increments has to be much larger, and unless there was a serious need for the 24-hr display, it took up too much valuable panel space.
ttpete
Dearborn, MI
The Navy used the AN-5741 Chronometer starting in late 1944, with them still in use in the P-3's well into the 1980's. The AN-5741 is a 3 1/8" instrument while the AN-5743's were 1 7/8" dials.
The AN-5743 is a clock movement only.
Here's a pic of an AN-5741. 24 hour, 5 dials.
