SyixString
- Joined
- Nov 7, 2021
- Messages
- 18
First of all, Hello all! - long time lurker first time poster - Im in dire need of some good good advice... i recently bought the Mr. Heater 50,000 BTU garage heater... its probably around 60 lbs. Would i be able to use these https://www.tannerbolt.com/default....zytMX9eU-bGr3RTE7uJn8nhz9l1bULVAaAtPbEALw_wcB with 3/8 threaded rod into them connected to the mounting brackets on the heater to hold it up... im guess im not sure if the rod threads going into the anchor would be strong enough to hold the heater up, i dont want the weight of the heater to destroy the threads and then it fall (if that makes sense)... i mean, i think it would be as its not a super heavy heater and there will be 4 anchors with 4 different rods... what are your folks thoughts on this? Thank you for any and all replies! means a lot!
