wantacoe
I am using 3 1/4" foam board insulation. I can only find a few screws that are long enough but then they are too heavy duty and expensive. Any ideas for some smaller more economical screws? Thanks
versico makes a foam adhesive called flexible dash. depends on what your substrate is but this is an option for youScrews and plates are hard to come by right now, How many do you need?
Not sure how many but it is for a 40x50x15 building.
the glues take longer to flash off in the cold but it can still be done.Could you glue them instead? I am pretty sure I have seen construction adhesive specifically for foam insulation. And there are some instant grab glues that I have used and worked great but they were for wood projects.
That may be an option but I am working in an unheated building. Not sure if the glue would dry in the cold?
I actually have been searching for something similar at a reasonable price, but just the washer itself. I found these thanks to some of words in your linkYou may want to consider glue and screws, you just need enough screws to hold the sheet in place until the glue dries. Here are some 4" screws with the insulation plate on them.
GenTite 4 in. Insulation Screws with Plates (100-Pack) GTI334S3SP - The Home Depot
Visit the Home Depot to buy GenTite 3-3/4 in. Insulation Screws with Plates (100-Pack) 21485200www.homedepot.com
Go to a roofing company that does epdm or sheet roofing. They use screws (with washer heads) to attach both flat & tapered rigid insulation to roof decks. You can probably buy a small quanity from them.
Consider using the Great Stuff style of expanding foam. Use the foam as an adhesive. Cures pretty quickly, and you can put a little on a test board to monitor cure time.
Maybe make a frame or ledge type support structure from vinyl stucco edge material. Or similar light and cheap material.
This, squirty foam cans glue insulation pretty well, can be messy though.This right here. Don’t use foam rated adhesives. Just use canned spray foam as an adhesive. Works WAY better than the foam rated adhesive.
It's through 3" of foam, not oak. Philips is fineI actually have been searching for something similar at a reasonable price, but just the washer itself. I found these thanks to some of words in your link
ADO Products 1.5 in. Square Self-Locking Insulation Anchors WAMK1512SM - The Home Depot
Secure insulation to wall anchors with the help of this ADO Products Square Self-Locking Insulation Anchors. Offers durability.www.homedepot.com
To the OP, just an FYI, as someone who has driven literally 10s of thousands of screws over the years, you don't want to be screwing any 4" screws of that have a philips head, get some good torx head..JMO
i have heard a lot of ppl using these in the recent weeksfollowing this rabbit hole of insulation anchors. I found that I can get 500 SS 3/4in fender washers for $20/delivered
these will suit my small need and I can use left overs on well alot of things.
500 Qty #8 x 3/4" 304 Stainless Steel Fender Washers (SNG817): Amazon.com: Industrial & Scientific
500 Qty #8 x 3/4" 304 Stainless Steel Fender Washers (SNG817): Amazon.com: Industrial & Scientificwww.amazon.com
rapidmaterials.com
