Mega Shed
nolatoolguy
Louisiana
They look cool, I wouldnt mind one. Along the gulf coast and sanfransisco theres yards with thousands of storage containers. You can get a 40x8 cargo containter for like one grands, sometimes less depending on conditiong
becuase theres not enough to export they dont wana send them back empty
Wingnut65
Tampa Bay, FL
We've definately have some sick puppies here on GJ. Guess that's why I feel right at home...
BTW, When you get it to your on back yard, you can do with it what you want to...
Stuart in MN
Minneapolis
Judging by the writing on them, they were some sort of train car.
It refers to a common method used to sort freight cars known as "*******," which involves the use of a man-made hill, or hump. A track heads up the hill and branches into numerous parallel tracks on its way down the other side. To make up new trains, a switch engine pushes a string of cars to the top of the hump, where the cars are uncoupled one at a time. Having determined the car's destination, a worker in a nearby tower pushes buttons or throws levers or whatever to get the track switches (you know, those things where one track divides into two) lined up properly. The car is then given a nudge, causing it to roll down the hump and onto the right track.
The advantage of ******* is that it's a lot faster than having switch engines shuttle back and forth all day making up trains. The disadvantage is that it's sometimes a little rough on the freight cars and their contents. Occasionally a car derails going down the hill, meaning the crew has to stop working and try to get the wheels back on the rails, which is not much fun, particularly in the middle of winter. What's worse is the possibility that the car may roll down the hill too fast and crash into the car in front of it, jostling or damaging both the cars and what's inside them. Special gimmicks on the rails called "retarders" are supposed to slow things down and prevent this, but they have been known to fail. Accordingly, cars with especially delicate contents are marked DO NOT HUMP, which tells the yard crew to set the car aside for special handling. This applies particularly to the tank cars used to haul hazardous chemicals, many of which have DO NOT HUMP stenciled permanently on their sides.
Earl
Echo, OR
We get those through the Union pacific yard here at Hinkle. They usually have airplane parts from Boeing. As stated above, the 'Do Not Hump' sign means they can not be allowed to roll freely down the back side of the hill into the classifying yard (or "Bowl"). They are also high and wide loads for the railroad which would mean getting them to your home would take some serious permits for the highway.
Earl
By the way, what is up with the drivel that cdef969 is posting? Look up his posts. He writes like the artist formally known as Prince used to talk. Most odd.
