Need some help identifying this C-channel
Mello03
I’m trying to add an axle to my aluminum trailer (not for more capacity but for safety) and I need to grab some of this channel. I have a guy that can weld this up, but I can’t find this channel. It’s 2x2.5 and has a t-slot obviously. Any help with a name for this configuration or the name of a aluminum manufacturing company that can help would be much appreciated!
marak
Anchorage, Alaska
That isn't a standard shape that I recall. Might check with Metal Supermarket, they have locations about everywhere, even here in Alaska.
Mello03
Yeah I can’t find anything. Thanks for the tip, I’ll reach out to them tomorrow.
VR6ix
Onterrible, Canuckistan
It's a custom-extrusion and might be proprietary to the trailer company. Square 2x2" tube is easy to find but 2x2.5" might be troublesome aka not a standard size. A good fabricator could jam something together and make it work with common material, but the mounting for new axle would be custom.
f150skidoo
Ontario, Canada
I highly doubt you will find anything from a normal metal supplier like Metal Supermarkets. If I were you I would be searching anyone in your area that sells aluminum extrusions and start calling.
Mello03
Thanks all. Yeah I will call the trailer manufacturer tomorrow and see what they say. I’ll also reach out to Alro Metals and see what I can get.
tarmy
Nor Cal
I know what it is cause I just bought some…for my sliding gate!
That is channel that a trolley rides in for a hanging sliding gate…the sticks I bought for my new set up is a bit different and beefier…but also a lot more costly. They tend to use very good aluminum in those too. The stuff I bought was from a company called Hoover gate in Ohio.
Mello03
Wow ok I’ll send them an email tomorrow. I hope you’re right! Thanks.
PFSard
Mesa, AZ
I have no dog-in-this-fight (?), in that I'll probably never use the knowledge. But I'm curious as to what your results/outcome are/is. For posterity. The level of knowledge of people who frequent this site amazes me.
tarmy
Nor Cal
There are several companies with proprietary dies for making that type of rail. You may need to check around for markings on that stick you have…or search for who sells something that looks just like yours. I found about 4-5 companies around the US that had various extrusions for the same purpose. The company I listed doesn’t show your profile on their site…so they may not help you. Just google hanging gate hardware and they will pop up…and see who makes your profile.
Good luck on your search…and get ready to pay…a lot…
Mello03
So I was finally able to talk to someone at the trailer manufacturer and they told me they own the die, and have that piece extruded. Good news is I can order it directly from them. Thanks for all the input!
f150skidoo
Ontario, Canada
I thought you weren't supposed to add a 2nd axle to that type of axle. I was looking to do the same.
Tandem torsion axles are pretty common. Only negative to them is they don't equalize the load between the 2 axles like standard leaf spring sprung axles. The risky thing about adding a second axle to a single axle trailer is the frame may be inadequate for the extra weight carrying capacity.
Mello03
Yeah Aluma has this same trailer size in a tandem axle and they are both torsion axles. The frame is different, so the load capacity is more. I am not going for more capacity, I am going for safety pulling my SXS that I have a lot of money into. In hindsight I should have got a tandem axle in the first place, but adding an axle and brakes is cheaper than selling and buying a new trailer.
PCustoms
VT
How does adding a 2nd axle to a trailer not designed for 2 axles make anything safer?
If your are within capacity, the single axle is fine.
Unless I'm missing something....
Mello03
4 tires on the road instead of 2 in case of a blowout, and it’s more stable pulling than a single axle.
kerrynzl
Tauranga, New Zealand
As long as the trailer's load capacity isn't exceeded then yes.
A puncture is a lot safer on a tandem than a single axle trailer.
Single axle leaf spring trailers are prone to roll-steer [swaying]
