My New to Me Tablesaw.
PoorUB
Fargo, ND
I do some woodworking and bought a Delta contrator saw back around 1995. I has served me well, but like most I wanted more power. I wasn't going to spnd $4,000 to $5,000 on a new cabinet saw, Jet, Delta, Powermatic, Grizzly or Sawstop, so I have been hunting Facebook Marketplace and Craig's List for most of the summer. Used Delta Unisaws go for $500 to well over $2,000 in my area with the lower end being fix'er uppers and generally older saws and missing parts, like the whole fence assembly. Newer complete ones are in the upper end, but usable complete saws are in the $1,500 and up range irregardless of the age. Same with the other brands mentioned. I have looked at adds for maybe a hundred saws, looking at saws in my area and hundreds of miles away.
We drove out to see our daughter in the Denver area over Thanksgiving and in my spare time I shopped that area and found a nice 3 HP Unisaw for $900. I was surprised it was still available when I contacted the seller as most of the time when the price was right the saw was gone shortly before. We all hopped into my pickup and drove out to take a look. The saw was owned by an older gentleman and he was fun to visit with. He had a nice place with a large two car sized shop in his backyard. He was 85 years old and selling off his "toys". He said he just didn't have the interest or ambition to get out and putz any longer. He told me he also had a mill and lathe he has recently sold. We looked over the saw and I didn't even argue about the price and said I would take it. My son-in-law helped and we stripped the saw down as it wouldn't fit in the short box typical on most pickups these days. The seller was a bit amused when I told him I wanted to flip it upside down to haul it. They are terribly top heavy and actually haul very well this way. Fortunately the seller had a small forklift so with the S-I-L we got it rolled over and onto the forklift and into the pickup.
We got back home a few days later and fortunately the weather was great as I was concerned about the cast iron top getting wet. Since then I have been getting it set up the way I like. I bought a set of heavy duty castors and a bunch of steel and built a roller base. Unlike some here I am limited on shop space so everything in my shop has to be portable and this saw is over 400 pounds so the roller base has to be fairly substantial. I also like having a large out feed table so I built one to fit using 3/4" melamine covered particle board.
Here are the before and after pics.
Welding up the roller base
Finished! I did disassemble an paint the base after this pic.
txlonghorn1989
Looks like you've got yourself a great saw and a very nice setup. Welcome to the Unisaw Club!
P
PoorUB
Fargo, ND
900 bucks. Wow!
That is borderline “You ****!” territory.
Good job, and enjoy that saw.
LOL! Yeah, I saw a couple of Unisaws of the same model variation in the $1,500 range that were a bit farther than I wanted to drive, so I wasn't going top argue about the $900. It kind of falls into that you almost **** range! :ROFLMAO:
I passed on one just like it, perhaps in a bit better shape that the seller was asking $2,600. Nice saw, but about $800-$1,000 over priced.
P
PoorUB
Fargo, ND
I need room to park my wife's SUV and my pickup in that space too. Now with two table saws it is pretty cramped, untill the other saw gets sold.
Boilerhouse
Muskoka
Great buy. I was going to suggest shelving or something to take advantage of the space under the outfield table, you you came up with a far better idea.
marak
Anchorage, Alaska
P
PoorUB
Fargo, ND
Well done OP…
maybe consider some better castors with locking mechanism.
They are locking. I don't have pictures showing the locking, but they are pretty good castors, rated for 300 pounds each. I can roll the saw around the shop with one finger.
They are not as robust as the ones you used, but plenty adequate for the job. Plus really good locking casters could cost more than the saw! I have a few casters laying around, but none I was comfortable using with this application so I ended up buying a set. You can easily spend $300 per caster!
tarmy
Nor Cal
What casters did you use? I have the same PM table saw and love it!
Edit: The casters appear to be E.R. Wagner...3"? I am using the 5" for a 2700# mill which works very well. A bit pricey at $39 ea, but they are very well built. https://www.amazon.com/gp/product/B003E7E854/?tag=atomicindus08-20
They are ER Wagner! 5”…
I use them or RWM…both are rated at 800lbs. Each.
I found, by accident, a great way to get them cheap…like 15-18 each cheap! When I need them I put both makes in my cart on Amazon…and wait. They are usually about 40-50 each…but as they get low they always would reduce the price…when it got low enough I bought the 1-3 they had left. Then repeat…image.jpgbuild up supply and have them ready for the next project. Probably did that 5 times….
tarmy
Nor Cal
They can get pricey…see my above post for a pro tip!
the other issue that took me some experimentation was flat spotting. The two I use now never have that issue…
Another issue I had was slab expansion joints and the lip on my garage slab and the approach slab. In summer I wheel my saw outside sometimes and the expansion joints are rather big in my garage. The 5” castors were needed to easily wheel over those obstacles…
like I said OP…nice build!
P
PoorUB
Fargo, ND
I really didn't have time to wait around for the perfect caster to go on sale. I needed the space in the garage to park our cars too and with winter coming I needed to get'er done.
If I had more time I would have hit the surplus shop and second hand stores. Heck, I have a box full of brand new casters from tool boxes I got for free a few years back, but I wasn't convinced they were built well for this application.
Max
Georgia
Just a thought on your old saw. When I got a unisaw, I kept my old contractor saw and with some plywood added I use it as an outfeed table for the unisaw. This lets me keep a dado blade always ready on the old saw, and I use the old saw‘s fence for the router as well. Let me know if you want a pic.
slowtwitch73
Hellgate
I have noticed more Unisaws for sale and for cheaper lately.
I think Sawstops, track saws and guys building benches with contractors saws built in is softening the market a bit.
P
PoorUB
Fargo, ND
Maybe you missed the out feed in the pictures?
I don't have room for two saws and no desire to keep two around if I had room.
If I wanted a second saw it would be a portable job site saw.
P
PoorUB
Fargo, ND
I wanted an in feed table for those times I juggle 4x8 sheet so I whipped this up from some extra melamine and oak. It "keys" into the rail for the fence. I just slide it in from the side. I need to figure out a leg, but a roller stand works for now. It gives me a bit over 5 feet before the blade.
P
PoorUB
Fargo, ND
I figured out a leg. After a bunch of searching, I bought this,
Table leg
It was too wide and too short, but on each side I cut the horizontal runs shorter before the curve down, and found some tubing that matched the outer diameter and added 7" to the height. Thank goodness I can screw up steel as easily as wood! :ROFLMAO:
Anyone need the other half to a set of table legs??
P
PoorUB
Fargo, ND
Just an Update, I sold my Delta contractors saw for $750. It took a few weeks on Facebook Market place, but I figured the right guy would come along and want it. A guy contacted me and after a few messages back and forth he sent his brother and son to pick it up, so he never looked at it to make the final judgement.
Through the negotiations I had his phone number so a few days later I asked him what he thought of the saw. He said he loved it, it was just what he was looking for! So he was more than satisfied.
I can out on the Unisaw pretty good. I paid $900 for it, sold my old saw for $750, but I added probably $400 to the saw getting it set up the way I wanted. So for $500-$600 I upgraded.
All I know is I am loving the HP. I needed to rip saw some 2x4 material. The contractors saw would struggle ripping material like this, the Unisaw just eats it up.
ez-duzit
Marina del Rey
One of my Unisaws (with carbide rip blade) is married to a contractors saw (with dado). Another Unisaw is married to a router table with an old 3-1/2 hp Stanley router.
