Quality headband head lamp that is bright
GophersGarage
Ontario Canada
Hi guys looking for a solution to my weak basic headlamp I currently have. Mine is low power yet uses a lot of batteries
I like something that is rechargeable style
your thoughts ?
Vicks
Dubai
+1 on Fenix - i've been using two of their head lamps regularly (atleast once every two weeks) for the past 13-14 yrs and they have never once malfunctioned/failed. They're definitely one of the best out there (i havent tried others because the Fenix never gave me a reason to haha) but do check out Ledlenser, they make some high quality stuff too.
brtsvg
Get a Fenix that uses the 18650 Li-ion battery. Much more power than the li throw-away batteries which are expensiv. Been very happy with my Felix HL-55, it lights up my entire back yard when it’s dark out.
Steve W.
Southwest oHIo
Personally, I would like to know a bit more about how you plan on using your new, "brighter" light.
I have tried several (cheap) lights over the years, and have found that for the way I use them, bright is not always good. If I am under a car or just needing some detail light on a bench project, too much light that close to my eyes just does not work. For stuff like that, my Harbor Freight unit works great. Yeah, it uses AAA batteries, but I use the HF rechargables. The light has a dimmer, which helps, too.
I do appreciate the brightness of the rechargable light I have (don't remember which (cheap) light it is, though. However, the brightness remains rather constant until the battery runs down. Then the light remains unuseable for quite some time while the battery charges. There is a bit of an advantage if you can swap out a fully-charged battery and keep going.
If you are looking for a light for night-time hiking or other stuff that is not quite so "in your face", bright is definitely an advantage. Definitely look for something with an 18650 or similar battery.
rlitman
Long Island
Personally, I would like to know a bit more about how you plan on using your new, "brighter" light...
Not that I'm recommending it, as it's getting outdated, but my Milwaukee 475 lumen headlight hits the sweet spot for me.
I use the lowest brightness settings when doing up-close work, but I use it at full brightness when doing gardening at night.
mike93lx
Richmond, VA
I've had pretty good luck with basic Duracell headlamps that are near the checkouts at places like target, Walmart and HD. I buy the ones with red as I mostly use headlamps camping, but for the roughly 15 bucks they cost, I can keep them all over the place and always accessible.
71charger
Here is one of mine and my brothers favorite. Uses a usb charger not proprietary, and works great.
12.99 Shipped have had them a couple years.
Steve_P
Black Diamond and Petzl are the standard brands in the outdoors/hiking/mountaineering world. They typically use AAA batteries, but just buy some rechargeable ones.
decableguy2000
I like Fenix lights. I have both of these. HM65r and the HL60r. The HM65r stays in truck and have a mount on my hard hat. The mount will fit either light. The HL60 s my go to head lamp for my hands free light around the house.
swedish_chef
Kansas City
I've been using this guy for the last 6 months or so:
I don't think it is 'the best' in any particular category, but it was the one that checked the most boxes for what I needed:
  • USB Type-C charging (though not PD charging -- I wasn't able to find any that I liked which supported actual PD charging above 5V)
  • Accepts both 21700 and 18650 batteries
  • Water 'resistant'
  • Lightweight (164g)
  • Both Samsung LH351D and Cree XP-L HD emitters
  • 90 CRI for the flood
  • Relatively inexpensive - ~$42 or so.
I'm not out spelunking with it, but I've been happy using it around the house and shop.
Alpine4x4
Central, WA
Black Diamond for me. Use it mostly for hiking in fishing early, but has other uses.
Rinspeed
NY
I like the (3) AAA units to keep the weight down. I must have six or seven of them made by Bushnell around the house. Also have a Black Diamond and a Nitecore as well. I use one of the Bushnell almost every day. I have a bunch of rechargeable AA and AAA batteries.
Pexto
Nobody has mentioned Zebralight yet? I've had mine for about 5 years and for the first time in my life I'm not constantly looking for a better headlamp. They are that good. I use headlamps a lot - in the shop, around the cabin, outdoors while skiing, cycling, hiking during long winter nights. However, be aware - they are not cheap, the model numbers can be confusing, and some folks find the user interface confusing.
I've got an H52w that takes AA batteries - I normally use rechargables. And I've got a H602w that takes 18650 Li-ion batteries - also rechargeable. These are older models no longer made; the newer ones are very similar; just have slightly better LEDs.
If I were buying one purely for shop use one of the floodbeam versions would be better than the above spot beams - something like the H53Fc or Fw.
javyLSU
New Haven, CT
Best headlamp I’ve ever used. I like it so much, I bought two:
Rechargeable, swivel head, lightweight, bright, adjustable brightness, and it’s magnetic so you can just pull it off and stick it on a piece of metal if you need a different angle.
Rinspeed
NY
Nobody has mentioned Zebralight yet? I've had mine for about 5 years and for the first time in my life I'm not constantly looking for a better headlamp. They are that good. I use headlamps a lot.
No idea why I forgot to mention Zebralight but they make one of the highest quality small lights in the world. I carry a SC52 every day and have for 10 years. I just don't always grab the head strap and use it on my head.
AirMech#406
Black Diamond is my go to. I use it regularly crawling around in fuselages. Not sure what the model is but I use rechargable AAAs in it. I have heard great things about Fenix as well.
germanwrenchguy
Berlin, BE
I have a Scangrip head lamp which in my opinion has the best beam pattern as far as headlamps. Its focused downwards so your work surface is properly illuminated. Only situation where that turned out to be non beneficial would be me working in a footwell dislocating as much joints as I can
Rinspeed
NY
Look for USB rechargeable, 500 to 1000 lumens, and adjustable angle.
The USB rechargeable light has to be one of the dumbest ideas I've seen come around in years. Why not just buy a light and spare battery so you're not waiting around in the dark for five hours waiting for the battery to charge.
Rinspeed
NY
the ones that are sealed battery usb I agree reminds me of my astro light
no removable battery so when dead its game over
That Fenix is going to be a little heavy just so you will know. You might not think it's a big deal but I just don't like the extra weight. Also I wouldn't use a made in China 18650 battery if they were free. Buy the light without the battery and get some quality Panasonic cells from Orbtronics and a decent charger such as XTAR.
https://www.amazon.com/dp/B08391KWYD/?tag=atomicindus08-20
https://www.orbtronic.com/protected-3400mah-18650-li-ion-battery-panasonic-ncr18650B-orbtronic
minke
fly over country
I've got several headlamps which use 3 AAA batteries (disposable or rechargeable). If the batteries fail in the dark you always need a second light to change the batteries. Mine also require a mind-meld with your origami teacher to open and close the lamp with the new batteries.
CJM8515
i have a petzl thats years and years old that i love. before they became super bright. also has a red filter. think it was called a tactical tikka
petzl, zebralight, black diamond, princeton tec, fenix are all quality units but costly. the entergizer ones are also good and cheap
decableguy2000
To the OP I think you'll like the HM65r, used mine for several hours yesterday. I find that medium flood setting is my most used. I have had no issues with the fenix battery that it comes with.
G
GophersGarage
Ontario Canada
I think you might be right might have to drop down to the HM50r or something its so hard online to pic this kind of thing. I have 3 Petzl now all are 3AAA and I also have the Petzl battery pack but not bright enough for automotive and battery use is crazy.
To the OP I think you'll like the HM35r, used mine for several hours yesterday. I find that medium flood setting is my most used. I have had no issues with the fenix battery that it comes with.
I will search it now thanks bud
G
GophersGarage
Ontario Canada
ok based on my Canadian amazon page here is what i have available
HM65rt $137 uses 18650
HM65r $125 uses 18650
HM61r $123 uses 18650
HM50r $97 uses smaller 16340
maybe the hm50r is good for automotive?
BreeStephany
Oregon
I really like my Milwaukee 2111-21 RED Lithium USB-rechargeable head lamp. I really like that the battery cells are removable so you don't have to grab another headlamp to wait for it to charge and can just swap out cells, let the drained cell charge and continue on with work.
I generally get a day and a half of run time (18~20 hours) off a charge and have been very happy with the light output.
Not quite the output of a 72000 lumen water-cooled flashlight 🤣, but PLENTY of light output for making sure I see what I'm working on in dark spaces.
