Over Workbench Extension Cord?
Masheen365
South GA
I just built a new workbench and after using it for about a week I’m realizing I need an overhead extension cord to make my life easier. What is everyone using for this kind of situation. I don’t really need a cord reel with 50-100’ of cord if I’m only using 10 feet or so. The shorter reels I have found are only 16ga which won’t meet my needs. I’m looking for ideas. My ceiling height is 11 ft. I will be using mostly woodworking tools in this area up to a 3-1/4 HP router but mostly orbital sander, jigsaw and palm router.
infinkc
I would just get a cord reel, even if you don’t need the extra length, it can come in handy if you do. I have a 25ft one, so they don’t have to be 50-100ft but yea hard to find. Thanks
mogandave
Bangkok
Nice bench.
You can get SO wire in the gage you want and put drops where you want them. Make them low enough where you can reach them and put a female twist-lock on the end.
Put together a few cords in different lengths with male twist-locks and change them out as needed.
Your bench has wheels. It you're planning on using it in several locations put a drop over each one.
If you have an air compressor, you can put air-drops in the same way with hose and disconnects.
I like drops at my right-most end of a bench rather than the center.
Cardboard Man
This is good advice. It's exactly what I use and I like being able to just reach up and pull down the cord when I need it. Mine is long enough that it will reach to all corners of my shop and also out the door. Very handy to use and puts itself away in seconds.
Max
Georgia
I use a cord reel as well. One thing to be aware of is that many cord reels are only rated for 8, or 10, or 12A. So look carefully at which tools you plug into it. I burned up one reel before I realized that my planer pulled 15A.
mogandave
Bangkok
A lot of them are junk too.
CraigStu
Blacksburg, Va
You could also get a heavy duty extension cord. Plug it into the nearest outlet, run it up to the ceiling, across to your bench, and down. Put a piece of hose, fuel line, or similar sleeve where it makes the 90 deg turn to come down to your bench. The sleeve will act as a strain relief so the cord doesn't get damaged. The most recent cords I bought at Lowes had their amp capacity easily read on the packaging.
CJDave
Fairfield, Ohio
A neighbor uses a cord reel from a old tank type vacuum cleaner. Maybe your local sweeper repair shop can help. CJDave.
kbs2244
does it have to be overhead?
a power strip along the front edge may be an easier solution
Bruce 993 SEA
La Conner, WA
If you get a cord reel, I would get one in 12 Gauge wire. I have them and they are handy.
There are cord grips for SO cord that is a strain relief...they are also referred to as finger traps.
yeldogt
I'm not sure what they are called .... I will call it a strain relief. At the woodworking school I go to occasionally they just have heavy cord hanging down from a typical looking box. The cord in using that strain relief at the box (looks like a string wrapping the cord)... the other end is just a typical looking extension cord. Some just hang down over the bench low enough for a sander or the like .... others higher up and swaged over with a spring ... so you can pull them down and plug in and they pop back higher. Keeps them out of the way and above head height
BillK
Beautiful Southern Maryland
The building that my shop is in was an appliance repair shop before I bought it. He had at least 10 drops spread out throughout the unit. They were SO cable with a metal duplex box on the end. Strain reliefs on both ends too. I left a few of them. I will take a couple of pictures in the morning.
Kaizen
New England
I got two of these and mounted to the ceiling. while they don't lock as well as the better ones they work great. Heavy construction. Its nice having reels on the ceiling and out of the way.
Bucko
I found that a peninsula rather than an island solves this problem. I put the tablesaw at the end and mount outlet boxes on the sides of the table. Makes running the central vac much easier and less restrictive then having to run it up to the attic and over.
rharman
SoCal
I'd use a cord reel. One of the best things I've ever bought for my garage.
Or, you might look at the Rockler Ceiling Track System.
mogandave
Bangkok
Agreed. But if you pull 15A through a reel rated for 10A (which I did) you can hardly blame the reel when it fails…. :)
It's been my experience that mechanical failure is more of an issue.
In any event, do they not generally some kind of breaker?
Max
Georgia
Most that I have seen, and all 3 of mine, do not have a breaker. The wires on the failed one were ok - what failed was the slip rings that carry current burned up.
mogandave
Bangkok
Perhaps a new law or something, all the ones I looked at on Amazon had breakers except this one:
But I only looked at five or six. Looks like the price has certainly come down since I bought them.
Sumboodie
AK
Those got spendy. I paid $4 each last spring for those. Bought 5 or 6 for my extension cords
tyyost
Tunkhannock, PA
When I worked in a school, the labs all had overhead drops with SO cord (12ga) and went into a utility box at the ceiling with a strain relief. At the end we has these Hubbell boxes. They were awesome, as they were more versatile than a single plug, and easy to see.
Masheen365
South GA
Thank you all for the replies! I'm going to do a deeper search into 12ga cord reels like Kaizen posted. I will try to remember to update here so future searchers might have something more to go on. I really like the hanging gang box like tyyost and BillK mentioned.
I've thought about making to do this. I already have an outlet in the ceiling for my garage door opener, but I plan on adding another on the same circuit right above the bench.
I'd really like it to be just for ease of use. A power strip would add a cord on the ground. I also like the idea of having my cords go up and not hang off the edge of the bench when I'm using the palm router, especially when making circles.
Absolutely! This is where I run into issues though. On one hand, I want something heavy duty that will last and safely support my higher draw tool (~15a). On the other hand, I'm cheap because I don't want to push my luck with the missus. I need to find where utility and frugality meet.
niget2002
Josephine, TX
When it comes to stuff like this... I find being cheap for the missus vs buying something that won't burn the house down to be a fairly easy decision.
Just ask her to skip her Starbuck's coffee a few days next week to help offset the difference in cost :D
brothernov
If it were me I'd place an electrical outlet at all four corners. Put the cord reel on the wall and pull it out to the bench to power the outlets when needed.
GaryM909
Calgary, Alberta, Canada
I have a couple I bought from Costco. I am not sure of the gauge but they have work flawlessly. I hung them about 4 feet behind the bench on the side I stand on.
C lectric
Canada
BillK photos show what are commonly called wire baskets in the trade. Also known as Kellems grips.
Generally available from electrical supply houses. Bought for a range of cable diameters. The ones he showed have the box fitting as part of the grip. I used to use a Tyrap at the end of the grip to be sure the drip gripped the cable.
Jinks
Daytona Beach
Never a fan of hanging power sources, reel or not. I built a mobile work table for my shop & to use in the drive when I didn't want saw dust & paint spray in the shop. I included a router mounted under the top. Wired the router to an outlet box on one leg & left a couple of outlets. The box ends in a pigtail with a three prong plug on it. On the end of the table I can hang a few tools & an extension cord. Where ever I set up to work it only takes a couple of seconds to run the cord to a wall outlet (I have plenty) & plug the pigtail into it. That gives me power for the router, & extra outlets for any power tool I'm using on top of the table. No reel to fuss with, & nothing to worry about hitting my head on....... :dunno:
C lectric
Canada
They don't have to hang down far enough to be a head banger. Use a bungee cord to hold them up about 7 ft which most of us can reach to pull down and plug/unplug the tool. Even attach a string to hang a few inches below that if needed.
I don't like power cords all over the floor. Clearly not always avoidable as I have those too but just keep it to a dull roar.
For my stationery bench the outlet boxes are at the bench ends just below the top.
SO the 'S' refers to a heavy cable insulation jacket made of nitrile rubber that is quite abuse resistant rated at 600V.
The 'O' means the jacket is oil and solvent resistant.
Add 'W' and it is water resistant. SOW
And SOOW cable means the individual wire insulation is also oil and solvent resistant.
There is a much lighter cable called SJ which has a 300V rating. THe cable jacket is much thinner.
A few explanations.
cvairwerks
Within hearing distance of Texas Motor Speedway
To keep cables and cords safe in our hangars, they installed a swing arm to the main desk. It carries two, 20 circuits and 8 Cat5 data cables. That supplies power for 3-4 desktops and up to 6 laptops, plus a mainframe terminal and two time clock terminals. The plug box height is set to be just above the shelf on the bench.
mogandave
Bangkok
They're not called Chinese finger-cuffs?
Kaizen
New England
Interesting that is uses 12g wire yet is only rated 15A. Derated due to its 40' length?
maybe or due to the tripple outlet. I've run my tablesaw which i believe has a 2hp motor and a dust collector without issue. I have mine on 20 amp circuits.
