wyliesdiesels
for the ubnt radio use an injector like thisSO my network equipment runs at 24v after looking. I do think I can do everything dc and avoid the inverter. If I have 2 big 12v deep cycle batteries running 24v will a 200watt panel be enough? My gate currently runs on a single 12v deep cycle battery on a 20watt panel.
DC - DC Converter + PoE Injector 12 VDC In and 24VDC PoE Out (Din Rail Mount) - AIR802 Manufacturing Antennas Cable Connectors PoE
AIR802® part number PDCPOE1224DR is a DC to DC converter with power-over-Ethernet or PoE output. This model has a 10 to 24 vdc input range and a 24 vdc output as PoE. It is DIN rail mountable. This unit supports passive PoE or IEEE 802.3af Mode B PoE.
www.air802.com
the radio takes about .5a @ 24v so you need about 12w for the radio
