BetterDays
Made progress on this dust collection system. Next will be finding some adapters for the hose to make it work better, since the main hose is now connected backwards. Guess this means another trip to the big box!
Once it is warm again, I will paint it up and smooth up the top plate.
rharman
SoCal
Nice idea to save space using the legs atop the casters. Is wobbly at all? I was thinking it might need stringers to sort of box in the legs.
BetterDays
Thank you to a random YT selection for the idea. 😃
It is actually pretty stable. The top of the pvc is screwed to the board, so that helps with stability. After some use, I will add more stabilization as needed.
BetterDays
Labeled and put away some extension cords. Now, I just need to find a better way to roll them / store them, especially in cold weatherPXL_20211231_153736721.jpg
Outlander
Quebec, Canada
Deliveries arrived, so I kept working on my homelab. Nothing spectacular, added 1u panel and swapped unruly ethernet cables for short ones between the patch panel and switch. Reevaluated next steps, ordered a 2U panel to minimise open space. After that runs for a while I'll re-work the final cable management - but that requires downtime and has to be planned between working from home and Netflix :)
Before:
Work in process:
After:
[soon to be added!]
More purging - it is kind of therapeutic to see my floor again. So much so I looked at the easiest way to slap on some paint (no, I'm not going to pull out cabinets and workbenches!
Purging included getting rid of old paint. 5 minutes on the city website and I found the place that took 2 minutes of my time. Should have done this 25 years ago.....I'm sure there were a couple of cans of that vintage! My PSA for the day....purge that which requires purging!
In the TV room section, besides dusting, I installed my new Android TV streamer (Christmas gift). So much nicer than using my phone and the Bell Fibe app (which works, but is a bit clunky).
Last day of the year, zero excuse to not work on my electronics and 3D printing projects! We are headed back into lockdown for the next few weeks so I'll have ample opportunity!
rayra
Escaped from Los Angeles
@BetterDays - I coil them like that, but I use a few feet of the tail end to cinch them in the middle then pass the plug end thru the loop to keep them bundled. If you finish with the prong end, makes them real easy to put back in use, you undo the prong end and pitch the coil to deploy.
as for 'in the garage', I'm doing a whole lot of nothing and will continue doing nothing for another 2-3 weeks, until my toe amputation heals sufficiently.
But once it does, I'm framing in a corner of the garage workshop area as a semi-secure storeroom. Then I'm working up some more ogive-ended beams for the pergola project. Then it is forming some hog- or cattle-panels to make cages for some stacked-stone gabions in the front yard. And then it is time to put some pull-down stairs in the garage ceiling and do some major whole-house attic insulation and ventilation projects.
welder4956
Birmingham, AL USA
Cleaned MAP sensors on the air intake for the 2015 Expedition to fix a intermittent rough idle condition. Then started pre-fabbing the copper supply line to the new air hose reel. Just need to hang it and tee into the the main line.
rayra
I hate to ask the obvious question, but WTF did you do?
Damaged it. Tore my feet up with some ill-fitting new workboots, during weeks of 18hr days packing and moving my folks out of CA. Treated it, insufficiently, infection became MRSA and rapidly worsened. Went from weeks of slightly red to suddenly swollen and necrotic in just 72hrs, MRSA, bone at the tip infected, foot starting to redden. ER, hospitalized, couple kinds of IV antibiotics. 48hrs later it was 'have to take your toe to save your foot - or worse.' and off that little piggy went to market. Took the whole toe, 2nd and 3rd bones ok, but flesh destroyed. So whole toe.
Surprisingly pain free and so far the protective sandal / overboot is more of a hindrance to my walking than the lack of the 2nd toe.
/It's a good thing I can still count to 20 without it, or I'd be in real trouble
In seriousness, been dealing with Type 2 diabetes for several years, I'd thought effectively. I've lost a lot of weight but that isn't enough, eat better, very active, but it wasn't enough. Left leg problems started about 10yrs ago when I lacerated both shins removing some aluminum siding from our mountain house. Left shin got terribly infected multiple times. MRSA, MRSA, MSSA, Pseudomonas. Wrecked the shin and my circulation, much like a 3rd degree burn, patch the size of your spread hand on the shin. Been wearing a compression sock on that scar tissue / foot for years. Wear a shin guard on that leg whenever I'm doing something that might injure my shin.
Have had slow healing despite good peripheral circulation in that left lower leg ever since. Rest of me heals just fine. So wore / tore some skin and callouses off my feet, tip of the toe look a long time and wound up infected.
Already tossed the boots and the next pair will damned sure fit better. I've got a lot of home remodeling and furniture making to do in the next couple years.
PassnThru
Bowling Green KY
Finished up with the repairs on the garage screen doors yesterday and got a coat of primer on last night. Today was a top coat and it looks like it's going to take another one so my evening has been planned for me.
sweetk30
finger lakes area upstate ,ny
Cleaned out the air compressor corner . Then made a shelf out of some heavy expanded metal . Then loaded it up with my 9 jack stands / 3 chunks of railroad iron .
Magnum440d100
Indiana
Spent Christmas at my brothers, and when I went to leave, we loaded up 2 55 gallon barrels. So today, I cut the tops off, and now have 3 burn barrels.
So, I’ve been burning trash. So while that’s goin, I decided to finally futz with my one garage door with an opener (other 2 are manual). It would start to go up, then stop and return down. Or when I helped it up all the way, it would stop halfway down and come back up.
Figured the springs were worn. So in true garage journal fashion, BOTH garage doors got new springs hahahaha.
I knew the manual door needed a new spring when I bought the place. It was broken, had mismatched springs, and the cables were everywhere. It was a pain in the fuggin **** to open. So when the OTHER side needed springs, I just bought all four and did them all.
The manual door now works flawless! I don’t plan on opening it all too often, as that’s the side with my shortbed dodge that is now a garage queen!
And now the powered garage door opens and closes smoothly.
I hope I’m not jinxing myself on the double door…
Crowbarman55
MRSA is not fun. Had it in my ankle a couple years ago. Had a bad reaction to the antibiotics that made me real sick too Took weeks to be able to walk without pain.
Now back to our regular schedule thread.
Todd
BetterDays
Took down the Christmas spotlights.
Wound up and labeled extension cords.
Replaced lights on the house to soft white (instead of red/green/disco ball snow fall)
Installed attic antenna.
Lubed garage door hinges.
Checked tire pressures (winter tires)
jmf535
Continued working on Kaizen foam-ing my tool box...drawer #2, complete.
This time I got smart, and covered the whole sheet in tape, and drew a grid pattern on it. The grid pattern made it much easier to line everything up, and to get it spaced out properly. Then the tape, itself, made it a lot easier to cut.
The end result.
DGersic
DeKalb, IL
A few pages back, I added two HF 1500 lumen flashlights to my snowblower. Earlier this week, we got our first snow, so Tuesday evening they got their first trial.
Overall, the idea works, but with some problems.
1. I must have caught one on some part of my truck. One of the plastic clamps got broken. Easy solution, buy another one. $0.26 each on clearance at Lowes.
2. After a while, the lights flicker.
3. The focus adjustment is probably fine as a flashlight, but doesn’t stay put when attached to the input scoop of a snowblower.
The flickering problem is pretty simple. The LED assembly is threaded in to the flashlight body. It’s not even finger tight. Add some vibration, and it wobbles in the threads, making intermittent contact, and flickering. The fix, tighten that thing down.
The adjustment sliding focus thing, maybe fixed. Unscrew the focus lense. Unscrew the LED. module. Pull the sliding thing off the barrel. There is an O ring, that provides a bit of friction, probably good enough for the intended use as a flashlight. Not for this.
I added a wrap of black electrical tape to the barrel. It covers the sliding area perfectly. It also adds some friction, and keeps the slider from rattling around on the barrel. We’ll see if that’s enough.
For now, they're ready for the next trial.
pyro3256
Oklahoma city
Started the process of cleaning and making the garage a usable space. It has served as storage. We moved into house 4 yrs ago. But I have never got around to moving in the garage.
so the first step was getting to “yard sale” status. And cleaning, so I could move in the vidmar cabinets I scored.
this is a good start. I may go back and get some cabinet sized ones to go under a soon to be work bench.
anyone have suggestions on drawer liner that can fit these in one piece?
Can anyone date these? Is there a model or type or something? I’m new to vidmar, will need a few parts. Also what casters to use? I know these were supper heavy.
619DioFan
San Diego , Ca.
I have all my extension cords on the round orange cord reels available at HD , walmart , etc. easy to transport and after use easy to roll back up, I store them in a cabinet on edge so very easy to grab. could also be hung on a wall.
niget2002
Josephine, TX
Aquarium stand progress.
Face frame glued to one side. Using the steel frame to keep things square. Pretty happy with the seam on the corner.
Will glue the other side tonight and then work on the doors tomorrow.
BetterDays
Made progress on a much much much needed clean out and organization for my "workshop". Still more to go, but getting closer!!! I had to quit the "what if I need this" mentality and just get rid of stuff I don't use and have not used for years.... If ever.
Part of my motivation is getting a shop smith (to be stored against the peg board) in the next few weeks. Yes, it takes up a foot print, but can give me a chance to try my hand at some woodworking and get it out of my dad's shed. :)
vwpieces
Hills, PA
Helped a buddy install some fixtures and wire the led tubes i gave him for his garage.
Gave me a broken cord reel. Fixed it up and swapped it out for a junky crapsman one I had. Old one would heat up the wire just using a shop vac on it. 20220101_173754.jpg20220101_174810.jpg
He also gave me a smaller bench top scroll saw... but it raining hard and still in the trunk of car.
  • Like
Reactions: OCD
4x4Pete
Stroud
Repaired a leaking plug on the old Kubota. Seems that a plastic snap in plug where the optional 4x4 front drive shaft exits the gear box is known for leaking.
  • Like
Reactions: OCD
Skinny_Blinky
Best on recovery.
4x4Pete
Stroud
What year make and model is the Kubota? A few more photos maybe?
I think its a 1982. Kubota aren't easy to date from this era. It's a B5100e, 2 wheel drive 2 cylinder diesel liquid cooled. 12 hp but it seems to have plenty of torque. I plow snow with a 60" rear blade on the 3ph without problems. It has a 2 spd rear pto and a electronic clutch option for front pto off the crankshaft. I added 200lbs ballast on the front lto help with steering when the plow is raised. Also tried the pizza cutter front wheels since the turf tires are so wide. It's a fun little tractor I picked it up this past fall. Excellent operating condition it was stored indoors its whole life. Thanks for asking!
Skinny_Blinky
Thank you. I really like that old(er) tractor in the line of Kubota(s).
A nice looking machine and very clean. Great find.
Attached is an old manual I have of that year/series if it is of interest to you. I snagged a lot of Kubota's information when their site had it posted about 15 years ago, when I bought a 2006 B7800. Still got it.
I like that Kawasaki also. Nice looking older bike.
  • Kubota_B5100-B6100-B7100_Owners_Manual.pdf
