Doall model j bandsaw
532r5
Flemington New Jersey
Just recently got my hands on a doall model j contour bandsaw. Previous owner started to disassemble in hopes of restoring but never got around to it. It seems to be nearly complete but no v belts. I looked hi and low but can't find what size they are supposed to be. Any help would be greatly appreciated. Thanks in advance.
landlord30
Pittsburgh, PA
Don't know which size saw you have, there's at least a 12" and 16" version.
see if this helps - last post on this link
532r5
The model j is a 12 inch. From what I found the newest it could be is 1937.
matt_i
SE Michigan
If its just a classic v-belt you need a couple of measurements. Most likely its a "B" section belt with 5/8" width across the top of the trapezoidal cross-section. If you have one already from something else, fit it into a sheave groove to see if it fits.
Then you need a tape measure, measure centerline distance between sheaves. Also measure both sheave ODs.
Your belt will be very close to (OD1 + OD2) / 2 / pi + the centerline distance.
Lets say that measurement is 32", you want to order a B32 belt.
They might have them stocked at an Ace Hardware where if it wasn't quite right then it could be exchanged.
Another tip is to look at the "belt takeup" or the mechanism which tensions the belt. Ideally you want it somewhere in the center when doing the measurements.
532r5
Thanks for the reply. This machine has a variable speed drive which uses 2 different size belts. As you change speed one pulley gets narrower as the other gets wider. In order for this to work properly the belts need to be a specific length. Short of calling doall I have not been able to find this information anywhere.
tool_scrounge
Southern California
I had the same problem with my late 50's 16" Do-All. In my case the belt length information out there was also wrong. So measuring and trying with cheap belts (to start) is probably the way to go. But running with quality belts in the end is best. You can probably still buy belts from Do-All, but the prices will be quite high.
superspec
WM louisiana
Can’t you take a string and go around both pulley and then measure the string length? I don’t see it being very hard to get really close to the side needed but maybe I’m missing something
matt_i
SE Michigan
Ah. Its a "Reeves Drive" variable pitch sheave. Those roll a little differently. Its unlikely the OEM is going to give you the specs on a new on as nobody would ever buy it from them because of the OEM markup. I have been down this road with Clausing. Once you have a belt in your hands you could probably reverse engineer it.
I think you are stuck with the OEM for parts assistance from (model + serial number) unless you find someone with identical saw willing to help reverse-engineer the belt. Eventually armed with the specs you can deal with Applied Industrial Technologies or Motion Industries to source the belt. I have dealt with DoAll a couple of times for a couple of parts issues and they seemed pretty helpful and it was easy to reach and speak to a technician who was able to assist. Really the only place you won't be happy is the price but its not a thing you'll likely have to replace more than a couple of times in a lifetime.
532r5
You are correct. I will try and call doall this week. Thank you for the input.
LeonardY
Southern California
I have a reeves drive on Delta lathe. I used a link belt and removed or added links until I was happy. Then measured it and found a belt that was the matched the length.
b974k
Mentor Ohio
Just go to DoAll's web site. They are still in business, They are the inventers of the modern type band saw
